So my computer is a dell studio xps 435MT. My dad recently upgraded some parts from the factory one. He put in a corsair ax750 power supply, 12 gb of ram, and an ati radeon 6770 1gb (i think it's like an XOC brand). Ever since that has happened, i have had problems with it freezing. Not all the time, and only when i play video games for 2-3 hours. And after it happens once, it will repeatedly happen again after that whenever i try to play games. It does it no matter what game i'm playing. Team fortress 2, battlefield 3, MW3, Minecraft, doesn't matter. So here's the deal, when this happens, usually the screen will freeze, followed quickly by the monitor turning black, and after a second or 2, turn back on. With the resolution being about 600x800. Big. And the only way to fix the resolution is by starting the task manager, and ending the game i was playing. That's all it requires. And just a few minutes ago, it wasn't just the screen that flashed on and off, my whole computer actually froze, but it started like the other times with the monitor first. So my question is, what do you think the problem is? I talked to both my uncles, who are big techy guys, and from what i had described, sounded like the gpu was overheating. But i turned the fan onto 70%, same thing happened. And the temp isn't that high, only about 56 degrees C. Correct me if i'm wrong, but is it a CPU issue? Or a motherboard? I wouldn't be surprised at either one, as both are fairly old, and probably being dell, not the best quality. Except the cpu, which is a first gen Intel Core i7-920. Any and all help will be greatly appreciated, thank you
