Approximate Purchase Date: Within this month most likely this week/next.
Budget Range: $2000 Aus Budget.
System Usage from Most to Least Important: Hardcore gaming (B3, SC2, SOASE, Civ4/5, D3, Skyrim etc)/Internet Surfing (5-15 tabs), Movies/TV, study, youtube.
Parts Not Required: Case (BitFenix Raider), Keyboard (Logi G510), Mouse (Razor Naga), Headset.
Preferred Website(s) for Parts: PLE.com.au, Austin.net.au
Country: Australia Perth (there is price differences between West and East)......yea i know Australia sucks with prices.
Parts Preferences: 24-27inch monitors, Intel CPU, Nvidia GPU.
Overclocking: Yes, up to around 4.5ghz, fan/air cooling only.
SLI or Crossfire: Yes in the future when i get enough cash for my 2nd GPU.
Monitor Resolution: Unknown havn't decided monitors yet most likely will be around 1920x1080.
Additional Comments: This is my first build i want it to be a high mid-end computer for gaming, i want it to last between 1-2 years on the top resolution for new games between then. This isnt only a gaming only machine, its also an entertainment machine focused at gaming. Here are afew extra issues which i would like looked at.
1. Is it worth getting a sound card for my build of this budget? Sound cards are the one piece of hardware which i have researched the least about, and i still havnt decided if it is worth getting one at this stage.
2. Is there any issues with compatablity, size, or overkill/bottlenecking, which should be addressed in this build?
3. In the future i will be getting 2 monitors set up, but for the moment 1 monitor is all that is needed, and has to be included in the budget, suggestions on which 1 from the sites prefered would be apprecated.
Current Build/System setup
Case: BitFenix Raider Mid Tower Case
N/A
Motherborad: ASRock Z77 Extreme6 Motherboard $199 from PLE
www.ple.com.au/ViewItem.aspx?InventoryItemID=609220&Cat...
CPU: Intel Core i5 3570K $242 from PLE
http://www.ple.com.au/ViewItem.aspx?InventoryItemID=609...
Ram: Corsair Vengeance CMZ8GX3M2A1600C9 8GB (2x4GB) DDR3 $65 from Austin
http://www.austin.net.au/ProductList/ProductDetail/tabi...
Graphics Card: EVGA GeForce GTX 670 2GB FTW
Not available in perth have to order over in east for $529
http://www.pccasegear.com/index.php?main_page=product_i...
CPU Cooler: CoolerMaster Hyper 212 EVO CPU Cooler $39 from Austin
Powersupply: Corsair HX-750 Power Supply $209 from Austin
Hard Drive: SEAGATE BARRACUDA 3.5" 2TB 64MB 7200RPM (ST2000DM001) $129 from PLE
http://www.ple.com.au/ViewItem.aspx?InventoryItemId=608...
SSD: Corsair Force Series 3 120GB SSD $145 from PLE
http://www.ple.com.au/ViewItem.aspx?InventoryItemID=607...
Optical Drive: LITE-ON iHAS-324 24x SATA DVD-R/RW/DL BLACK $26 from PLE
http://www.ple.com.au/ViewItem.aspx?InventoryItemId=601...
OS: Microsoft Windows 7
N/A
Total: $1583 AUS, excluding monitor/soundcard.
Thanks for the imput, greatly appreciate all the advice (which i hope will come
![:D :D]()
