Sufficient Power Supply for this build?
Hi all,
I'm super close to finalizing an mATX build. I've purchased much of the below pcpartpicker list, just haven't decided which case, PSU, and video card. My biggest question at this point is the power supply. I know I want a modular supply since the cases I'm considering aren't exactly known for their cable management (InWin Dragon Slayer, Fractal Design Arc Mini, Silverstone TJ-08). The below build is estimated at ~380W (I put in the 7950 since I'm pretty sure it draws more than the GTX660ti and GTX670 I'm considering... worst case scenario):
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($181.03 @ Microcenter)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($26.82 @ NCIX US)
Motherboard: ASRock Z77 Pro4-M Micro ATX LGA1155 Motherboard ($109.99 @ Amazon)
Memory: Samsung 8GB (2 x 4GB) DDR3-1600 Memory ($49.00 @ B&H)
Storage: Western Digital Caviar Black 500GB 3.5" 7200RPM Internal Hard Drive ($78.24 @ SuperBiiz)
Storage: Kingston HyperX 3K 120GB 2.5" Solid State Disk ($99.99 @ Newegg)
Video Card: Gigabyte Radeon HD 7950 3GB Video Card ($309.99 @ NCIX US)
Case: Fractal Design Arc Mini MicroATX Mini Tower Case ($99.98 @ NCIX US)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($15.99 @ Newegg)
Total: $971.03
(ignore the prices, my build will come in ~$80 less :))
So my two questions are:
1) I'm looking in the 500-600W range... is there ANY reason I would regret not getting something with more power if I never plan on adding a second video card?
2) I've pretty much narrowed the PSU choice down to these four, would love to hear opinions on best value for the money:
Antec BP550 Plus ($56)
SeaSonic M12II 520 Bronze ($75)
Rosewill Capstone 550-M ($80)
Antec HCG-620M ($80)
Any help is appreciated!
3 answers Last reply
More about sufficient power supply build
  1. I would get one of these three choices:
    XFX 550w
    XFX 650w
    Corsair CX600
    Any of the ones you listed should do OK, though. Most that are $1 per 10w are built pretty well. I just trust the ones I listed more. Out of the ones you listed, I would probably go with the SeaSonic one.
  2. Rosewill Capstone-550M.
    It is the best out of the ones listed, and probably better than anything else in its price range.
    This is because it is the most efficienct: 80 Plus Gold efficiency vs 80 Plus Bronze at best for the others.
    It has independent voltage regulation, the only other unit mentioned which isn't group regulated is the XFX 650W.
    It is modular, which the XFX and Corsair units aren't.
    It uses nothing but Japanese capacitors, only the Seasonic M12II Bronze 520, Antec HCG-620M and the XFX units also only use Jap caps.
    It has a 5 year warranty. The only other units which also have a 5 year warranty are the Seasonic M12II Bronze 520, XFX 550W & 650W. Others are 3 years.
    It has the slowest spinning fan and therefore the highest chance of being quiet. It's fan is capable of spinning up to 1200/1500RPM, but most likely it will be remain at 700RPM even at full load.
    The others might start at 600RPM, but by 50% load they will be over 1000RPM and by full load some of them will reach 1800RPM.
    I hope to illustrate with the list above that some competiting units can match the Capstone-550M in certain aspects, but not all aspects, therefore it comes out ahead of everything else.
    Review for Capstone-550M:
    http://www.hardwaresecrets.com/article/1584
    If you are going to add another 7950 in the future then I'd suggest going for the Capstone-650M or 750M.
  3. Thanks Silvune! Between your post and Raiddin's post, I've pretty much narrowed it down to the Rosewill vs the Seasonic, leaning towards the Rosewill. Gonna keep my eyes out the next few days for any price drops though!
Power Supplies Build Components Product
