Hi,
Ill check if the fan is spinning on the weekend.I'll list my system info in one sec.
Game Booster Diagnose Report v1.0
Version: 3.5.0.1517
Date: 2012/05/01 07:24:02
01 - Operating System
0101 - Operating System : Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.111025-1629)
0102 - Language : English (Regional Setting: English)
0103 - BIOS : BIOS Date: 07/26/2006 Ver: 08.00.12
0104 - Processor : Intel(R) Pentium(R) D CPU 3.00GHz (2 CPUs)
0105 - Memory : 2048MB RAM
0107 - Page File : 905MB used, 7053MB available
0108 - Windows Dir : C:\WINDOWS
0109 - DirectX Version : DirectX 9.0c (4.09.0000.0904)
0110 - DX Setup Parameters : Not found
0114 - DxDiag Version : 5.03.2600.5512
02 - Processor
0201 - Caption : Intel(R) Pentium(R) D CPU 3.00GHz x2 ~2999MHz
0202 - Current Clock Speed : 2999MHz
0203 - L1-Cache : 32.00 KB
0204 - L2-Cache : 4.00 MB
03 - Video Adapter
0301 - Card Name : NVIDIA GeForce 8400 GS
0302 - Manufacturer : NVIDIA
0303 - Chip Type : GeForce 8400 GS
0304 - DAC Type : Integrated RAMDAC
0305 - Device Key : Enum\PCI\VEN_10DE&DEV_06E4&SUBSYS_34CD1458&REV_A1
0306 - Display Memory : 512.0 MB
0307 - AdapterRAM : 512.00 MB
0308 - Current Mode : 1280 x 1024 (32 bit) (60Hz)
0309 - Monitor Name : hp L1702 flat panel monitor
0310 - Driver Name : nv4_disp.dll
0311 - Driver Version : 6.14.0012.9610
0312 - Driver Language : English
0313 - DDI Version : 9 (or higher)
0315 - Driver Beta : False
0316 - Driver Debug : False
0317 - Driver Date : 3/1/2012 09:58:00
0318 - Driver Size : 4309760
0319 - VDD : n/a
0320 - Mini VDD : nv4_mini.sys
0321 - Mini VDD Date : 3/1/2012 09:58:00
0322 - Mini VDD Size : 13417632
0323 - Device Identifier : {D7B71E3E-45A4-11CF-6252-C11400C2CB35}
0324 - Vendor ID : 0x10DE
0325 - Device ID : 0x06E4
0326 - SubSys ID : 0x34CD1458
0327 - Revision ID : 0x00A1
0330 - Video Accel : ModeMPEG2_C ModeMPEG2_D
0331 - Deinterlace Caps : {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
0334 - DDraw Status : Enabled
0335 - D3D Status : Enabled
0336 - AGP Status : Enabled
0337 - Notes : No problems found.
To test DirectDraw functionality, click the "Test DirectDraw" button above.
To test Direct3D functionality, click the "Test Direct3D" button above.
0338 - OpenGL : 5.1.2600.5512 (xpsp.080413-0845)
04 - Memory
0401 - Total Memory : 2.00 GB
0402 - Free Memory : 1.12 GB
0403 - Total Pagefile : 7.77 GB
0404 - Free Pagefile : 6.88 GB
0405 - Bank Label : BANK1
0406 - Speed : NULL MHz
0407 - Total Width : 64 Bits
0408 - Capacity : 2.00 GB
05 - Network
0501 - Description : Realtek RTL8139/810x Family Fast Ethernet NIC - Packet Scheduler Miniport
06 - Motherboard
0601 - Model : Asterope3
0602 - Manufacturer : Hewleet-Packard
07 - Sound Device
0701 - Description : Realtek HD Audio rear output
0702 - Default Sound Playback : True
0703 - Default Voice Playback : True
0704 - Hardware ID : HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_103C2A3D&REV_1000
0705 - Manufacturer ID : 1
0706 - Product ID : 100
0707 - Type : WDM
0708 - Driver Name : RtkHDAud.sys
0709 - Driver Version : 5.10.0000.6526
0710 - Driver attributes : Final Retail
0711 - Date and Size : 12/13/2011 17:27:30
0713 - Driver Provider : Realtek Semiconductor Corp.
0714 - Min/Max Sample Rate : 5372994, 5372994
0715 - Static/Strm HW Mix Bufs : 5372994, 5372994
0716 - Static/Strm HW 3D Bufs : 5372994, 5372994
0717 - HW Memory : 5373002
0718 - Voice Management : False
0719 - EAX(tm) 2.0 Listen/Src : True, True
0720 - I3DL2(tm) Listen/Src : True, True
0721 - Notes : To test DirectSound functionality, click the "Test DirectSound" button above.
No problems found.
08 - Hard Disk
0801 - Model : ST3160815AS(Seagate, 160G)
0802 - Media Type : Fixed hard disk media
0803 - Size : 149.05 GB
0804 - Interface Type : Serial ATA
0801 - Model : Generic USB CF Reader USB Device
0802 - Media Type : NULL
0803 - Size : 0
0801 - Model : Generic USB MS Reader USB Device
0803 - Size : 0
0801 - Model : Generic USB SD Reader USB Device
0803 - Size : 0
0801 - Model : Generic USB SM Reader USB Device
0803 - Size : 0
0805 - Driver Date : 7-1-2001
0806 - Driver Version : 5.1.2535.0
0807 - Caption : C:\
0808 - Capacity : 142.43 GB
0809 - Free Space : 65.18 GB
0810 - Drive Type : 3-Fixed
0811 - File System : NTFS
0807 - Caption : D:\
0808 - Capacity : 6.60 GB
0809 - Free Space : 425.44 MB
0811 - File System : FAT32
09 - Process
0901 - 0000 Idle 0 0
0901 - 0004 System 0 0 normal
0901 - 0318 smss.exe 0 0 normal C:\WINDOWS\system32
0901 - 03b8 csrss.exe 68 75 normal C:\WINDOWS\system32
0901 - 0400 winlogon.exe 37 14 high C:\WINDOWS\system32
0901 - 0450 services.exe 4 2 normal C:\WINDOWS\system32
0901 - 046c lsass.exe 4 2 normal C:\WINDOWS\system32
0901 - 0564 ASCService.exe 32 27 high C:\Program Files\IObit\Advanced SystemCare 5
0901 - 0594 svchost.exe 4 1 normal C:\WINDOWS\system32
0901 - 061c svchost.exe 4 1 normal C:\WINDOWS\system32
0901 - 067c svchost.exe 11 31 normal C:\WINDOWS\System32
0901 - 079c svchost.exe 4 1 normal C:\WINDOWS\system32
0901 - 0118 svchost.exe 8 7 normal C:\WINDOWS\System32
0901 - 0184 spoolsv.exe 5 4 normal C:\WINDOWS\system32
0901 - 021c Explorer.EXE 240 123 normal C:\WINDOWS
0901 - 03c8 dsmonitor.exe 5 2 normal C:\Program Files\Uniblue\DriverScanner
0901 - 03d8 BoostSpeed.exe 156 69 normal C:\Program Files\AVG\AVG PC Tuneup
0901 - 0494 ehtray.exe 25 13 normal C:\WINDOWS\ehome
0901 - 05d0 hpsysdrv.exe 7 3 normal C:\windows\system
0901 - 0600 KBD.EXE 21 36 high C:\HP\KBD
0901 - 064c HPwuSchd2.exe 8 3 normal C:\Program Files\HP\HP Software Update
0901 - 068c issch.exe 4 1 normal C:\Program Files\Common Files\InstallShield\UpdateService
0901 - 06f0 TelstraUCM.exe 54 37 normal C:\Program Files\Telstra\Mobile Broadband Manager
0901 - 05ec RTHDCPL.EXE 89 60 normal C:\WINDOWS
0901 - 0738 jusched.exe 5 2 normal C:\Program Files\Common Files\Java\Java Update
0901 - 0100 coreServiceShell.exe 5 4 normal C:\Program Files\Trend Micro\AMSP
0901 - 0134 RunDLL32.exe 47 7 normal C:\WINDOWS\system32
0901 - 05f4 Apoint.exe 81 40 normal C:\Program Files\DellTPad
0901 - 0370 ctfmon.exe 18 11 normal C:\WINDOWS\system32
0901 - 0378 netsession_win.exe 8 4 normal C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\Akamai
0901 - 039c ASCTray.exe 66 37 normal C:\Program Files\IObit\Advanced SystemCare 5
0901 - 0778 netsession_win.exe 8 7 normal C:\Documents and Settings\HP_Administrator\Local Settings\Application Data\Akamai
0901 - 07b8 ApMsgFwd.exe 8 4 normal C:\Program Files\DellTPad
0901 - 0578 hpqtra08.exe 14 34 normal C:\Program Files\HP\Digital Imaging\bin
0901 - 05a8 sqlmangr.exe 141 92 normal C:\Program Files\Microsoft SQL Server\80\Tools\Binn
0901 - 0410 HidFind.exe 7 5 normal C:\Program Files\DellTPad
0901 - 0288 uiWatchDog.exe 5 2 normal C:\Program Files\Trend Micro\UniClient\UiFrmWrk
0901 - 02a4 Apntex.exe 12 8 normal C:\Program Files\DellTPad
0901 - 02ac svchost.exe 5 3 normal C:\WINDOWS\System32
0901 - 032c coreFrameworkHost.exe 4 1 normal C:\Program Files\Trend Micro\AMSP
0901 - 0670 arservice.exe 8 4 normal C:\WINDOWS
0901 - 05d8 uiSeAgnt.exe 14 20 normal C:\Program Files\Trend Micro\UniClient\UiFrmWrk
0901 - 085c BBSvc.EXE 5 2 normal C:\Program Files\Microsoft\BingBar
0901 - 08cc SeaPort.EXE 5 6 normal C:\Program Files\Microsoft\BingBar
0901 - 0958 ehSched.exe 4 8 normal C:\WINDOWS\eHome
0901 - 09f8 jqs.exe 5 2 idle C:\Program Files\Java\jre6\bin
0901 - 0b84 LSSrvc.exe 5 1 normal C:\Program Files\Common Files\LightScribe
0901 - 0bb8 MDM.EXE 5 3 normal C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG
0901 - 0bf0 sqlservr.exe 5 1 normal C:\Program Files\Microsoft SQL Server\MSSQL$MICROSOFTSMLBIZ\Binn
0901 - 0c18 nvsvc32.exe 13 5 normal C:\WINDOWS\system32
0901 - 0c24 PnkBstrA.exe 5 1 normal C:\WINDOWS\system32
0901 - 0c4c svchost.exe 5 2 normal C:\WINDOWS\system32
0901 - 0a80 wuauclt.exe 5 4 normal C:\WINDOWS\system32
0901 - 0524 ehmsas.exe 10 13 normal C:\WINDOWS\eHome
0901 - 08c4 alg.exe 5 2 normal C:\WINDOWS\System32
0901 - 0f98 chrome.exe 68 46 normal C:\Program Files\Google\Chrome\Application
0901 - 080c chrome.exe 210 1 below normal C:\Program Files\Google\Chrome\Application
0901 - 09bc dllhost.exe 5 3 normal C:\WINDOWS\system32
0901 - 0a90 chrome.exe 28 44 normal C:\Program Files\Google\Chrome\Application
0901 - 14f4 wmiprvse.exe 8 8 normal C:\WINDOWS\system32\wbem
0901 - 08c8 chrome.exe 147 1 normal C:\Program Files\Google\Chrome\Application
0901 - 12e4 GameBooster.exe 1611 111 normal C:\Program Files\IObit\Game Booster 3
0901 - 17b0 gbtray.exe 55 43 normal C:\Program Files\IObit\Game Booster 3
0901 - 1018 FPSClient.exe 33 27 normal C:\Program Files\IObit\Game Booster 3
0901 - 1478 wmiprvse.exe 8 6 normal C:\WINDOWS\system32\wbem
10 - Service
1001 - Advanced SystemCare Service 5 - [C:\Program Files\IObit\Advanced SystemCare 5\ASCService.exe]
1001 - Akamai NetSession Interface - [C:\WINDOWS\System32\svchost.exe -k Akamai]
1001 - Application Layer Gateway Service - [C:\WINDOWS\System32\alg.exe]
1001 - Trend Micro Solution Platform - ["C:\Program Files\Trend Micro\AMSP\coreServiceShell.exe" coreFrameworkHost.exe -m=rb -dt=60000 -ad]
1001 - ARSVC - [C:\WINDOWS\arservice.exe]
1001 - Windows Audio - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Bing Bar Update Service - ["C:\Program Files\Microsoft\BingBar\BBSvc.EXE"]
1001 - BBUpdate - ["C:\Program Files\Microsoft\BingBar\SeaPort.EXE"]
1001 - Background Intelligent Transfer Service - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - COM+ System Application - [C:\WINDOWS\system32\dllhost.exe /Processid:{02D4B3F1-FD88-11D1-960D-00805FC79235}]
1001 - Cryptographic Services - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - DCOM Server Process Launcher - [C:\WINDOWS\system32\svchost -k DcomLaunch]
1001 - DHCP Client - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Media Center Scheduler Service - [C:\WINDOWS\eHome\ehSched.exe]
1001 - Event Log - [C:\WINDOWS\system32\services.exe]
1001 - COM+ Event System - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Fast User Switching Compatibility - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Java Quick Starter - ["C:\Program Files\Java\jre6\bin\jqs.exe" -service -config "C:\Program Files\Java\jre6\lib\deploy\jqs\jqs.conf"]
1001 - Workstation - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - LightScribeService Direct Disc Labeling Service - ["C:\Program Files\Common Files\LightScribe\LSSrvc.exe"]
1001 - TCP/IP NetBIOS Helper - [C:\WINDOWS\system32\svchost.exe -k LocalService]
1001 - Machine Debug Manager - ["C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE"]
1001 - MSSQL$MICROSOFTSMLBIZ - ["C:\Program Files\Microsoft SQL Server\MSSQL$MICROSOFTSMLBIZ\Binn\sqlservr.exe" -sMICROSOFTSMLBIZ]
1001 - Network Connections - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Network Location Awareness (NLA) - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - NVIDIA Driver Helper Service - [C:\WINDOWS\system32\nvsvc32.exe]
1001 - Plug and Play - [C:\WINDOWS\system32\services.exe]
1001 - PnkBstrA - [C:\WINDOWS\system32\PnkBstrA.exe]
1001 - Protected Storage - [C:\WINDOWS\system32\lsass.exe]
1001 - Remote Access Connection Manager - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Remote Procedure Call (RPC) - [C:\WINDOWS\system32\svchost -k rpcss]
1001 - Security Accounts Manager - [C:\WINDOWS\system32\lsass.exe]
1001 - Task Scheduler - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - System Event Notification - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Windows Firewall/Internet Connection Sharing (ICS) - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Shell Hardware Detection - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Print Spooler - [C:\WINDOWS\system32\spoolsv.exe]
1001 - System Restore Service - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Windows Image Acquisition (WIA) - [C:\WINDOWS\system32\svchost.exe -k imgsvc]
1001 - Telephony - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Terminal Services - [C:\WINDOWS\System32\svchost -k DComLaunch]
1001 - Themes - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Windows Management Instrumentation - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Security Center - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
1001 - Automatic Updates - [C:\WINDOWS\system32\svchost.exe -k netsvcs]
1001 - Wireless Zero Configuration - [C:\WINDOWS\System32\svchost.exe -k netsvcs]
12 - Event Log
1201 - Time : 1/05/2012 5:18:53 AM
1202 - Source : DCOM
1203 - Description : The server {7F6316B4-4D69-4765-B0A3-B2598F2FA80A} did not register with DCOM within the required timeout.
1201 - Time : 1/05/2012 5:17:23 AM
1202 - Source : Service Control Manager
1203 - Description : The NVIDIA Update Service Daemon service failed to start due to the following error:
The service did not start due to a logon failure.
1203 - Description : The nvUpdatusService service was unable to log on as .\UpdatusUser with the currently configured
password due to the following error:
Logon failure: the specified account password has expired.
To ensure that the service is
configured properly, use the Services snap-in in Microsoft Management
Console (MMC).
1203 - Description : The Media Center Extender Service service depends on the SSDP Discovery Service service which failed to start because of the following error:
The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
1203 - Description : The HID Input Service service terminated with the following error:
The system cannot find the file specified.
1203 - Description : The Computer Browser service depends on the Server service which failed to start because of the following error:
1201 - Time : 30/04/2012 2:31:24 PM
1201 - Time : 30/04/2012 2:29:46 PM
Console (MMC).
End of file - 22735 Bytes
Thats my system info, got it from gamebooster.
