Hello all. I'm attempting to configure my first desktop gaming machine from AvaDirect. I don't have any experience in configuring a desktop gaming system and am not very knowledgeable about the importance and quality of various components. I've done some research online, in forums, videos, etc, and have put together a potential system as a starting point.
I was hoping someone could review the system I've put together below and give me some feedback. As said, I'm an amateur so please excuse me if any of parts don't work well together, or if the system in general just isn't efficient due to my lack of know how.
Please help to save money where I've foolishly spent it on a part that's not necceary or is overkill, and help redirect money to parts that I've skimped on where, perhaps, I shouldn't have. My budget is $2000 ish
Here are my answers to some starting point questions:
Approximate Purchase Date: August 2012
Budget Range: $2000ish
System Usage from Most to Least Important: Gaming (graphically intensive first-person-shooters, etc.), primary MultiMedia center for full HD movies in the home, internet (lots of tabs and windows).
Major Concern: Heat, I want the system to run as cool as I can afford while still being able to afford top tier performance, if possible... GPU and CPU cooling. I have very little knowledge on how to achieve this.
2nd Major Concern: How does Sandy Brige vs Ivy Bridge affect my build/performance for the purposes I've outline above? Should I be considering Ivy Bridge only? The present configuration is Sandy Bridge, see below.
Parts Not Required: monitor, speakers
Preferred Website(s): AvaDirect, or any other reputable builder.
Country: USA
Parts Preferences: Full Tower, I guess.
Overclocking: Yes, done by AvaDirect, any advice here is appreciated (not very knowledgeable about overclocking)
SLI or Crossfire: I don't really understand SLI or Crossfire, so maybe? (advice, lesson, appreciated).
Monitor I'll be using: Hanspree 1080p LCD Television 27" for now. But eventually I'd like to be able to run Two 24" 1080p LCD Monitors if possible, gaming with two screens.
Here's the configurator I used on avadirect: http://www.avadirect.com/gaming-pc-configurator.asp?PRID=19571
Here's my potential/starting point build:
CPU: Intel Core i7-2700k Quad-Core 3.5-3.9 Ghz, LGA 1155, 8mb L3 Cache
Overclocking CPU: Mild Overclocking service, 10-20% performance increase
GPU, PCI Express x16 Video Card: XFX, Radeon HD 7970 1000MHZ 3gb GDDR5 5700Mhz, PCIe x16 CrossFire, DVI+HDMI+2x Mini-DP
GPU, 2nd one: None
Overclocking, GPU: Optimal and Stable AvaDirect service performed by AvaDirect
PSU: Cooler Master Silent Pro M 850W
Cooling: Noctua NH-D14 Air Cooling
Thermal Compound: Coolaboratory, Liquid MetalPad Conduction Pad, Metal
Liquid Cooling: None
Motherboard: CHANGED -- from Gigabyte GA-Z68A-D3H-B3, LGA1155, Intel z68, DDR3-2133 32GB /4, PCIe x16, etc. - TO, Going with ASRock Z68 Extreme4 Gen3, I'd like to have the DisplayPort
Ram: Mushkin 16 GB (4x4) PC3-16000 DDR3 20000MHZ
Sound Card: Integrated 8-Channel Audio Controller
SATA HD: Crucial 256GB M4 SSD 500-260 MB/s
HD, 2nd one: Western Digital, 1TB, SATA 6 GB/s, 7200 rpm, 32MB cache
Raid: NO Raid, of course
Optical Drive: LG WH12LS39 12x/16x/48x BD/DVD/CD Blu-Ray Burner, SATA, w/M-Disc
Wireless: HP FH971AA Wireless Adapter w/external antenna, Ieee 802.11b/g/n 13 Mbps, PCIe x1
Network Card: Integrated Controller
Tower Case: Antec, Three Hundred Black Mid-Tower, ATX
Cooling Fans: Stock Fans
Fan Controllers: None
Wire Management: Custom Wiring, standard wiring with precision cable rouging and tie down
Operating System: None, have a copy of Windows 7 Ultimate already.
Keyboard and Mouse: Microsoft Wireless Desktop 800 2.4 GHZ RF
Warranty: Silver Warranty Package (3 Year Limited Parts, 3 Year Labor Warranty)
So, what do you think? Constructive criticism is welcome as are suggestions, alternative builds, and alternative sites to build from.
Thanks very much in advance.
Country: USA
GPU, 2nd one: None
