B boucher19 Honorable Apr 30, 2012 6 0 10,510 May 1, 2012 #1 Hello, I am looking to sli two 550 ti. My current power supply is a Ultra LSP650 650-Watt. I am running an AMD phenom 1055t. Thanks, Mike
ilysaml Splendid Oct 30, 2010 4,854 0 23,460 May 1, 2012 #2 It's not a quality branded PSU and seems to be really sucks, but since the 550ti uses a little power you should be fine. If it has the required PCIE 6 pin connectors then you're good to go. Upvote 0 Downvote
B boucher19 Honorable Apr 30, 2012 6 0 10,510 May 1, 2012 #3 Thanks, I couldn't find anywhere exactly what the 12v needed to be for SLI, this PSU has 38a. Upvote 0 Downvote
