Hi there i have a wireless home phone and an android Huawei S7 with the Indonesian 2.2.2 installed on it I'm wondering if it is at all possible to get the mobile to ring with the home phone it runs on 5.8 GHZ and isn't linked directly to the modem there are 2 phones on the home line a wired system near the wall point then two three meter cable run to the modem and wireless phone they are connected through a Telstra wall point it has a phone connection on to and a phone and modem connection on the side its comes off the wall on a 30cm cable if i cant get it to connect directly can i force the modem to pick up calls and transmit to the mobile through my wireless network
Thanking you in advance
Harley
Harley
