$2000 build. First build need advice. Willing to go up to $3000
Last response: in Systems
I mostly play RTS computer games such as SC2 and Supreme Commander 1&2, but I'm tired of playing them on low to medium settings. I found this thread on this site and wanted to know if anybody had any tweaks or recommendations that might better suit me. My budget is $3000, but I'm trying to stay under $2500. If anybody has any recommendations for monitors as well it would be appreciated. Even if it's overkill for what I want to do I just want to have a really nice gaming computer as an end of deployment present to myself.
$2000 - Gamer (Enthusiast) - $1,946.90 w/rebates $2,041.90 w/o rebates
CPU : Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) $360
http://www.newegg.com/Product/Prod [...] 6819116501
Motherboard : GIGABYTE G1.Sniper 3 LGA 1155 Intel Z77 $280
http://www.newegg.com/Product/Prod [...] 6813128552
RAM : G.SKILL Ripjaws X Series 8GB (2 x 4GB) $60
http://www.newegg.com/Product/Prod [...] 6820231445
CPU Cooler : ZALMAN CNPS12X 120mm Long Life Bearing High Performance Triple Fan CPU Cooler $100
http://www.newegg.com/Product/Prod [...] pk=cnps12x
SSD : OCZ Vertex 4 VTX4-25SAT3-128G 2.5" 128GB $130 ($180 norm)
http://www.newegg.com/Product/Prod [...] 6820227791
HDD : Western Digital Caviar Green WD10EARX 1TB $95 (norm $99)
http://www.newegg.com/Product/Prod [...] 6822136939
PSU : SILVERSTONE Strider Gold ST85F-G 850W $155 (norm $170)
http://www.newegg.com/Product/Prod [...] 6817256067
GPU : EVGA 04G-P4-2673-KR GeForce GTX 670 Superclocked+ w/Backplate 4GB X2 $485 each
http://www.newegg.com/Product/Prod [...] 6814130785
Case : Corsair Vengeance Series CC-9011016-WW $140
http://www.newegg.com/Product/Prod [...] 6811139013
Extra Case Fan : COUGAR CF-V12HP Vortex Hydro-Dynamic-Bearing (Fluid) 300,000 Hours 12CM Silent Cooling Fan with Pulse Width Modulation $17
http://www.newegg.com/Product/Prod [...] 6835553002
(Use on the window slots for exhaust)
More about : 2000 build build advice 3000
That extra fan isn't needed and that motherboard is major overkill. Drop it to the Gigabyte GA-Z77X-UD5H. You also won't need the 3770K for a gaming system - if you get the i5-3570K you will save $100 there.
A single 4GB GTX 670 will max out everything at resolutions beyond 1080p for the next couple of years. Take that money you'd be paying for SLI and invest it in a good ultra high resolution monitor.
I'd also say swap that fan for a Noctua D14.
Would you recommend the Z77 ASUS or the Z77 GIGABYTE? Also, would an ultra good high resolution monitor be much better than connecting it to a 32" HDTV? This is more of an asthetics question, but what's a good brand for cool looking cases that light up and things like that and would work with all of the components here. Your reply was very helpful and I appreciate the input.
brandon0326 said:
Would you recommend the Z77 ASUS or the Z77 GIGABYTE? Also, would an ultra good high resolution monitor be much better than connecting it to a 32" HDTV? This is more of an asthetics question, but what's a good brand for cool looking cases that light up and things like that and would work with all of the components here. Your reply was very helpful and I appreciate the input.If you're going to connect to an HDTV that's fine - that's what I do on my build.
Either one is fine - Asus and Gigabyte are the best board makers in the industry.
If you want a case with plenty of fans and things like that try the Corsair Carbide 500R: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Related ressources
- New PC build $ 2000 willing , Or whatever is necessary. - Forum
- Need advice on $ 3000 build - Forum
- Want to build a Video/Photo Editing PC for $ 2000-$3000 - Forum
- 2000 $ first build ( advice appreciated) - Forum
- first gaming build 2000-3000 budget - Forum
Case:COOLER MASTER CM Storm Series Trooper (SGC-5000-KKN1) Black Steel / Plastic ATX Full Tower Computer Case
Case:NZXT SWITCH 810 Matte Black CA-SW810-M1 Steel / Plastic ATX HYBIRD Full Tower Gaming Computer Case
Case:COOLER MASTER Storm Sniper SGC-6000-KXN1-GP Black Steel, ABS Plastic, Mesh bezel ATX Mid Tower Computer Case
Case:COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
holy cow that is overkill. you can probably max those games with a 1200 dollar PC.
heres my pick. its around the 1600 dollar mark but you can always reduce it by using a hyper 212 evo instead of a silver arrow, using a asrock extreme4 motherboard instead of the ud5h, and using a cheaper case than the haf xm
http://pcpartpicker.com/p/aNHl
Case:Corsair Carbide Series 500R White Steel structure with molded ABS plastic accent pieces ATX Mid Tower Computer Case
Case:Antec Twelve Hundred V3 Black Steel ATX Full Tower Unbeatable Gaming Case
Case:Thermaltake Chaser MK-I (VN300M1W2N) Black SECC ATX Full Tower Computer Case
TheBigTroll said:
holy cow that is overkill. you can probably max those games with a 1200 dollar PC.heres my pick. its around the 1600 dollar mark but you can always reduce it by using a hyper 212 evo instead of a silver arrow, using a asrock extreme4 motherboard instead of the ud5h, and using a cheaper case than the haf xm
You could do that for even less:
Case: Corsair Carbide 400R - $99.99
PSU: PC Power & Cooling Silencer MKII 750W - $109.99 ($20.00 MIR)
Motherboard: Gigabyte GA-Z77X-UD5H - $179.99
CPU: 3.4GHz Intel Core i5-3570K - $229.99
Cooler: Cooler Master Hyper 212 Evo - $34.99
RAM: 8GB Crucial Ballistix Sport 1600Mhz 1.5V - $46.99
HD: Samsung Spinpoint F3 1TB 7200 RPM - $109.99
Optical: Lite On DVD Burner - $17.99
Video Card: EVGA Geforce GTX 670 - $399.99
OS: Windows 7 Home Premium - $99.99
Total: $1,329.90
i know i can. i changed this one up a little more for a lower price. you can hit the 1300 price point by dropping the SSD
http://pcpartpicker.com/p/aNKG
Some of your links seem to be a problem.
Games rarely use more than 2 or 3 fast cores. The extra hyperthreads of the 3770K are not worth the extra $100 over a 3570K.
All Z77 motherboards will do. Pick your favorite vendor, they are all good.
There is no need for an expensive enthusiast model that is oriented to high level overclockers and multi way sli.
Here are my thoughts:
1) With your budget, look for a great monitor first. Yes, it will be expensive. A 30" 2560 x 1600 monitor will be $1200 or so.
Or, a 2560 x 1440 27" monitor would be a second choice. About $800. A great monitor is one of the most "future proof" pc components you can buy today.
2) You pay a steep premium for the 4gb of ram, and it is of questionable value. Better to go ahead and spend $500 or so on a GTX680. Here is a superclocked evga GTX680:
3) The zalman cooler looks great. But, I do not like the proprietary fans. For a bit less, you can get a Noctua NH-D14 which is about the best air cooler, and the fans are as good as it gets.
Actually, a $30 cooler like the cm hyper212 would do just as well.
4) For reliability, I would look first to Intel or Samsung for a SSD. They make their own nand chips, and can do a better job of validation. They seem to have fewer issues. 120gb is a good size. It will hold the os and a handful of games. The wd green is fine for overflow storage.
5) I don't know who makes silverstone psu's; I think they are good. But a GTX680 only needs a 600w psu. And, you will never recoup the price premium for a gold rated psu from electricity savings. I will pay the premium for gold, and modular when mounted in a small form factor case, past that no.
I would suggest the PC P&C silencer750w unit. silver rated, for only $90 after rebate:
6) Cases are a personal thing. Buy the one you love. You will be looking at it for a long time.
For glamor, I like the looks of the Corsair Carbide Series 500R White :
For top quality, look at lian li cases too.
Personally, I prefer smaller cases, check my sig.
Good luck, and welcome back.
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($229.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($39.98 @ Newegg)
Motherboard: Asus P8Z77-V ATX LGA1155 Motherboard ($194.98 @ Newegg)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($48.99 @ Newegg)
Hard Drive: Crucial M4 128GB 2.5" Solid State Disk ($124.99 @ Newegg)
Hard Drive: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($99.99 @ Newegg)
Video Card: Asus GeForce GTX 670 2GB Video Card ($419.99 @ Newegg)
Case: Corsair 500R White ATX Mid Tower Case ($124.99 @ Newegg)
Power Supply: SeaSonic 650W ATX12V / EPS12V Power Supply ($145.98 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($21.98 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (64-bit) ($99.99 @ Newegg)
Total: $1551.85
(Prices include shipping and discounts when available.)
Total: $1551.85
After seeing some of the recommendations I've changed a few things to better suit my needs. Anything to change or add to make this better would still be appreciated.
CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
http://www.newegg.com/Product/Product.aspx?Item=N82E168... ($230)
Motherboard: GIGABYTE GA-Z77X-UD5H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E168... ($189)
CPU Cooler: Noctua NH-D14 120mm & 140mm SSO CPU Cooler (Will this fit on board?) http://www.newegg.com/Product/Product.aspx?Item=N82E168... ($105 $95 after rebate)
Video Card: EVGA SuperClocked 02G-P4-2682-KR GeForce GTX 680 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E168... ($520)
Memory: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
http://www.newegg.com/Product/Product.aspx?Item=N82E168... ($47)
Power Supply: CORSAIR Professional Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E168... ($150 $130 after rebate)
Case: COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E168... ($170)
SSD: Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E168... ($125)
Optical Drive: ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E168... ($17)
Hard Drive: Western Digital Caviar Green WD10EARX 1TB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E168... ($95)
Operating System: Microsoft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E168... ($100)
Total: $1,748 before Shipping and Rebates
brandon0326 said:
After seeing some of the recommendations I've changed a few things to better suit my needs. Anything to change or add to make this better would still be appreciated.CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
As far as a SSD goes, is it needed for the gaming use of this system or would the 1TB be sufficient. If you think that it would be better to have one which is better.
OCZ vertex 4 128GB or Crucial M4 128GB
Total: $1,623 before Shipping and Rebates
That all looks good to me. You can't go wrong with the Vertex 4 or the M4. The Vertex 4 is based on a new controller called Indilinx that's as fast as Sandforce but with the stability of the Marvell controller used in the M4, read more about it: http://www.tomshardware.com/reviews/vertex-4-everest-2-...
A very good revised list.
A SSD is not needed for gaming.
But with your budget, I would not omit one.
It makes everything you do feel much quicker.
Of the two, the crucial M4 is probably the better for reliability.
Read this: http://www.behardware.com/articles/843-7/components-ret...
Personally, I would prefer Samsung 830 or Intel 330 or 520.
geofelt said:
A very good revised list.A SSD is not needed for gaming.
I have an Intel 320 and hate it - it's constantly having issues with Windows, system restore, and Windows update - and that's mainly due to the Sandforce controller being used. I'm planning on swapping it for a Vertex 4 in the next couple of months, hopefully while Newegg still has the price that low.
Revised to show SSD and Total. Input on changes to the build that will make a significant difference, but still keep me under $2000 will be appreciated. I'm set on My case, Graphics Card.
http://www.newegg.com/Product/Prod [...] 6819116504 ($230)
http://www.newegg.com/Product/Prod [...] 6813128545 ($189)
CPU Cooler: Noctua NH-D14 120mm & 140mm SSO CPU Cooler (Will this fit on board?) http://www.newegg.com/Product/Prod [...] 6835608018 ($105 $95 after rebate)
http://www.newegg.com/Product/Prod [...] 6814130769 ($520)
http://www.newegg.com/Product/Prod [...] 6820231428 ($47)
http://www.newegg.com/Product/Prod [...] 6817139010 ($150 $130 after rebate)
http://www.newegg.com/Product/Prod [...] 6811119225 ($170)
http://www.newegg.com/Product/Prod [...] 6820148442
http://www.newegg.com/Product/Prod [...] 6827135204 ($17)
http://www.newegg.com/Product/Prod [...] 6822136939 ($95)
http://www.newegg.com/Product/Prod [...] 6832116986 ($100)
g-unit1111 said:
That extra fan isn't needed and that motherboard is major overkill. Drop it to the Gigabyte GA-Z77X-UD5H. You also won't need the 3770K for a gaming system - if you get the i5-3570K you will save $100 there. A single 4GB GTX 670 will max out everything at resolutions beyond 1080p for the next couple of years. Take that money you'd be paying for SLI and invest it in a good ultra high resolution monitor.
+1 - that MB is a tad overkill. I personally like ASUS' Sabertooth models and would recommend the Z77 model for the 5 year warranty:
I like Corsair for RAM, get a nice set 4X4GB set of 1600:
I don't trust OCZ for their SSDs after a lot of personal strife with the Vertex2 line. I love my Intel 520 from my Desktop rig or the Samsung 830 from my laptop - both are smoking fast and uber reliable. If you go Intel, the 180GB model has a slight write-speed advantage over the 120GB but it's not that noticeable. I have the 120 and have never been happier with my boot time.
I think with your budget, you could just as easily upgrade to a 680 so you won't have to think about SLI'ing for several years. The 670 is still a phenomenal card and is more than capable of handling today's games with ease - just something to consider. I prefer EVGA or ASUS for graphics cards but everyone has their preference.
Just my two bits...
Your links no workie.
1. Your gaming and have no need for hyperthreadinhg....the 3570 is therefore the way to go. The Sniper abit expensive and I'd look for a MoBo / CPU combo to save a few bucks:
Asus Sabertooth w/ 3570k - $445
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
RAM - Too cut down on IB's heat output, low voltage RAM might be a plus
Corsair CAS 9 DDR3-1600 1.35 V - $55
The Top Coolers with hi end thermal performance and low noise output are the Thermalright Silver Arrow and Phanteks coolers.....Zalman not in the same league....Phanteks has 5 year warranty and comes in choice of colors
http://www.newegg.com/Product/ProductList.aspx?Submit=E...
http://www.vortez.net/articles_pages/phanteks_ph_tc14pe...
SSD - One with premium toshiba toggle mode flash .... for extra long life and unmatched performance....and since budget allows, why not 240 GB ....especially since well at $0.83 per GB
http://www.tweaktown.com/reviews/4328/mushkin_chronos_d...
HD If ya going WD, ya want the black, green = slow
GFX - Asus TOP trounces the EVGA SC
http://www.guru3d.com/article/evga-geforce-gtx-670-sc-r...
EVGA SC Boost Clock is 1046 outta the box....stable at 1200 Mhz
EVGA SC gets 3DMark Score of 8691 outta the box and 9443 OC'd
Idle temp is 29C / load temp is 78C
Noise is 37 dBA Idle / 43 dBA under load
http://www.guru3d.com/article/asus-geforce-gtx-670-dire...
Asus TOP Boost Clock is 1137 outta the box .... stable at 1280 Mhz
Asus gets 3DMark Score of 9340 outta the box and 9839 OC'd
Idle temp is 30C / load temp is 72C
Noise is 37 dBA Idle / 38 dBA under load
That makes the Asus 7% faster outta the box than the EVGA SC, 6C cooler and almost 1/4 as loud under load (every 3 dBA is a doubling of sound level). The FTW is slightly faster than the SC, leaving the Asus model w/ just a 5% performance advantage.
Case Alternatives (both w/ 10.0 jonnyguru performance rated PSU's).
$280 - Corsair 500R - $125 w. Corsair HX850 - $155 after MIR and $10 promo
$260 - Antec DF-85 ($140) w/ CP-850 ($120)
$280 - Antec 1200 V3 ($160) w/ CP-850 ($120)
brandon0326 said:
Revised to show SSD and Total. Input on changes to the build that will make a significant difference, but still keep me under $2000 will be appreciated. I'm set on My case, Graphics Card.CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
1: boost the SSD size to 256gb. 128gb is kinda limiting on what to put inside the SSD
ersonally, the evga 670 ftw will be about as good as the 680 but 100 dollars less3:you wont need the extra space in the haf x so i would get the haf xm. same design but smaller
Hes already decided on his case you guys lol and his links ain't working but hes already revised his build which is solid recommending him to get a 680 is bad advice a 670 is only 5% slower what justify the extra $100 for a 680 not a dam thing it's a no brainer the 670 is the way to go i sure as hell wouldn't pay a extra $100 for a 5% increase in performance doesn't make any sense .
g-unit1111 said:
I have an Intel 320 and hate it - it's constantly having issues with Windows, system restore, and Windows update - and that's mainly due to the Sandforce controller being used. I'm planning on swapping it for a Vertex 4 in the next couple of months, hopefully while Newegg still has the price that low.Strange. My son has been using a 320 for years with no issues. Possibly there is a firmware update for it.
But, I was talking about the newer 330 series, which is apparently similar to the 520 series, just at a lower price point.
Thanks everyone for your quick responses and recommendations. I’ve got a friend that has done a few gaming builds and is currently deployed with me. Based on everyone’s recommended changes and opinions he has sorted out what he feels would be all around best. He definitely agreed on going with the 570 over the 580 because of the $100 price difference. What does everyone think about the second revised build? I'd like to get something finalized within the next couple days and appreciate all the help.
Iv'e put an * next to everything iv'e changed.
*Motherboard: ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard ($445 Combo)
*Video Card: EVGA 02G-P4-2678-KR GeForce GTX 670 FTW 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card ($420)
Power Supply: CORSAIR Professional Series HX750 (CMPSU-750HX) 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified ... ($150)
*Memory: G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBSR ($49)
CPU Cooler: Noctua NH-D14 120mm & 140mm SSO CPU Cooler ($105)
*Hard Drive: Seagate Barracuda ST1000DM003 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive ($100)
*SSD: Intel 330 Series Maple Crest SSDSC2CT120A3K5 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD) ($124)
*Case: Antec DF-85 Black Steel / Plastic ATX Full Tower Computer Case (I still like the HAF 942 though) ($140)
Optical Drive: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM ($17)
Operating System: Microsoft Windows 7 Home Premium SP1 64-bit - OEM ($100)
Total $1,650 before shipping and rebates
Related ressources:
- Forumhttp://www.tomshardware.com/forum/ [...] rts-stores
- Forum[New Build ] Need advice . First time build . $ 2000 budget.
- ForumPlease help, £ 2000-£3000 Gaming/Editing PC
- Forum$ 2000 -2500 Gaming Rig build advice needed
- ForumNeed advice on a NZD$ 3000 Gaming Computer
- Forum$ 3000 First Computer Build
- ForumBuilding a $ 3000 Gaming PC, advice please? [Updated]
- ForumGaming Build ~$ 3000 Budget, need advice on finalization!
- Forum3000 Budget Build Advice
- ForumXfx 680 half price
- More resources
