My Build:
GIGABYTE GA-Z68A-D3H-B3 LGA 1155 Intel Z68 ATX Intel Motherboard
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I72600K
Intel 320 Series SSDSA2CW080G310 2.5" 80GB SATA II MLC Internal Solid State Drive (SSD) - OEM
Western Digital Caviar Green WD7500AARX 750GB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
CORSAIR XMS 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX8GX3M2A1600C9
ATI 100-505606 FirePro V4800 1GB GDDR5 PCI Express 2.0 x16 Workstation Video Card
CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
Windows 7 Professional
This is my first computer build, which I based heavily off the suggestions from Dassault's official forums on a Solidworks rig for work. Twice in one month, my power supply has blown out. I am connected through a UPS into the wall socket. The first time my PSU blew out, my coworkers mentioned a "pop" sound from my case, with the ceiling lights flickering (sounds like a surge). Our facilities are quite poor, so I am not surprised we have surges, which is why we have UPS's at each computer. The PSU failed the paperclip test and Corsair replaced it one month ago. I swapped out the UPS with a different one (thinking it may not be protecting properly), and one month later, my computer would not turn on, and the new PSU failed the paperclip test this morning. Based on my build, a 650W PSU should be sufficient (I used a PSU calculator and even added a couple hundred extra watts to be safe). This computer is used to run CFD (computational fluid dynamics) simulations for days on end (very high CPU use for up to a week straight). I use an aftermarket cooler on my CPU to keep things nice and chilly (30-40deg C). In general, the computer performs just fine despite the heavy use.
I am at a complete loss of why this is happening. The UPS should be preventing a surge from injuring my equipment (every other device plugged into the UPS has been totally fine after a surge, and the UPS itself reacts and resets itself after a loss of power from the wall.) Could this be related in any way to the build itself? I followed a Dassault professional's advice very closely on components for my build. Perhaps there is an issue with running at high CPU load for days on end? A blown out PSU seems extreme. Again, I want to stress that our facilities are quite poor, and power outages/surges are not uncommon, hence the UPS's at each desk.
I would greatly appreciate any advice on what is going on here, as the computer is used heavily amongst the small company I work at. Thank you!
