Hi everyone!
Long time reader, first time poster, so bear with me here.
I am currently in the process of building a new Gaming/Media Center Rig. My idea behind this rig was something small and inconspicuous, yet something so powerful it'll blow away any budget gaming PC, as there is no actual budget for this one. I want to make a monster, really.
Here's what I have so far
Intel Core i5 3570K CPU
MSI Z77MA-G45 Mobo
Corsair XMS3 16GB RAM
Thermaltake TR2 RX 750W PSU
Sapphire Radeon HD 6950 OC Edition GPU
And this cooler Cooler Master X6 Elite
And all of this is in this tiny little case
Cooler Master Elite 343
And I know you're wondering, but no, the CPU cooler doesn't fit in the case perfectly, I had to bend the side panel a bit to get it to fit(small price to pay for extreme performance in a tiny package)
Now for the questions.
First off, would this case have enough cooling performance to be able to handle another 6950 crossfired?
Also, if it is able to handle crossfire, would I want to try to overclock them or no?
Regarding the CPU, how high of a stable clock would I be able to achieve with the cooler that I have, but also considering how small the case is?
Would you recommend overclocking the RAM also, or would it get too hot and fry my motherboard/ram?
How exactly would you go about the overclocking process? As in, in which order would you overclock first? i.e. CPU, then RAM, then GPU?
How do I overclock?(First time I'm able to have decent enough income to get a computer worthy of overclocking)
I do have a 120mm fan in the front that came with the case, and I also installed a 92mm fan in the back(the fans are in push pull configuration), but there was no room for the one to put on the side panel, so take this into consideration if and when you are answering my questions.
Thanks a lot!
MSI Z77MA-G45 Mobo
Thanks a lot!
