theidiotthatisme
7
Looking for an HTPC style computer to hook up to my current setup, that includes a 1080p HDTV, 5.1 surround sound with receiver via HDMI. I actually do most of my gaming on a Playstation 3, so I won't really be running many games other than SimCity and Civilization.
Approximate Purchase Date: Mid-August
Budget Range: $700-$1,000
System Usage from Most to Least Important: Playing SimCity (5), Organizing and playback of music collection, Playback of Video (DVD's, possibly BluRay, ripping to ISO's).
Parts Not Required: Monitor, Speakers
Preferred Website(s) for Parts: 1. Amazon.com, 2. Newegg.com
Country: United States
Parts Preferences: None
Overclocking: None
SLI or Crossfire: None
Monitor Resolution: 1920x1080
Additional Comments:
My current setup includes a 55" LED LCDTV, a 5.1 surround sound system through a Yamaha A/V receiver, and a PS3/Wii. Most of my gaming and movie watching is done through the PS3, but it's horrible at managing any kind of music collection over a few CD's, so I'm mostly looking to play non-console games and a good way to organize and play music. Because of it being an HTPC style computer, I'm hoping to keep the noise at or below a game consoles level. I don't have a Windows disc (all I have is a Toshiba laptop that has the recovery partition), and am looking for a wireless keyboard for playing the games from the couch.
Here is my list for your HTPC for $757 w/ SSD
Core i3-2120/H61/8GB/1.5TB HDMI SuperCombo $366
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.956695
LITE-ON Black 12X BD-ROM w/ software $70, because you need the blu-ray if you want to watch 3d you need the 3d playback software.
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106451
SAPPHIRE Radeon HD 6670 1GB 128-bit GDDR5 $75, this card is basic games card also is good for 3D BR if you want to upgrade 3D TV.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102958
Windows 7 Home Premium SP1 64-bit $100
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
If you want you can add the SSD in your HTPC for Intel 520 60gb $70 or SanDisk(120gb)/Crucial M4(128gb) about $120.
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100008120%20600038478&IsNodeId=1&bop=And&CompareItemList=636|20-171-567^20-171-567-TS%2C20-167-092^20-167-092-TS%2C20-148-442^20-148-442-TS
voodooking
298
I don't know about SimCity but I do know about Civilization V. My current build has a difficult time playing the game at Medium/low settings. I am upgrading to an i5 2500K because my processor is so weak. But I don't think you would have to go with the best gaming cpu just not something in the tier 5 section of the "best gaming cpu's for the money" column. Have you read those? There are two columns on Tom's that talk about cpu's and gpu's. They rank them in tiers. Just go up to the tabs at the top of the sitte and click articles and look for "The Best of... for the money."
http://www.tomshardware.com/reviews/gaming-cpu-review-overclock,3106-5.html
http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-7.html
I would assume, based on my experience that 3rd or 4th tier Cpu would be fine to play at least medium. I wouldn't go anything lower than a 7th tier for the GPU. In fact in my new build I am sticking with my current card until I get the money for a 3rd tier one. I've learned the hard way.
Another thing is Ratios. Tom's does build articles (that are great reading) where they are putting 40 to 50% of their money in the GPU. It's that important. So just keep in mind that, in your budget range, $300 to $350 is a great target for a GPU.
Best of luck!
The key for a HTPC is to start your search for a case. Most will be ITX or M-ATX based.
The rest of your parts will be determined by that.
Here are two M-ATX cases.
Antec New Solution NSK2480 http://www.newegg.com/Product/Product.aspx?Item=N82E16811129034
Silverstone Grandia Series GD05B http://www.newegg.com/Product/Product.aspx?Item=N82E16811163166
I know there are others, and some are particularly beautiful(and expensive).
Inside, any sandy bridge dual core cpu should do the job. I might pick the G850 @$88, up to the i3-2125@160.
I know civ2 and civ4 run well on integrated graphics. Don't know about civ5 or sim city.
It might be a good strategy to try integrated first, and add a discrete card later if you really need to.
The HD3000 graphics on the 2125 is stronger than the HD2000 graphics on the G850.
Any M-atx motherboard with a Z77 chipset should do. Pick your favorite brand.
I do like a ssd for the os and a few apps. 60gb is minimum, 80gb or 120gb is better. Look first to Intel or samsung.
The number of hard drives on these cases is limited. If you are storing video files, buy a 2gb or larger drive.
Can't help on a good laptop style remote keyboard. No experience there.How would you handle mouse actions?
I think there are some such keyboards with a trackball for that.
theidiotthatisme
7
I decided to add in the shown requirements for SimCity for when it's supposed to launch:
Processor:
AMD Athlon 64 X2 Dual-Core 4000+ or better
Intel Core 2 Duo Processor 2.0 GHz or better
Operating System:
Windows XP/Vista/7
RAM:
Windows XP: 1.5GB
Windows Vista and Windows 7: 2GB
PCs using a built-in graphical chipset are recommended to have 2 GB RAM
Graphics Card:
ATI X1800 or better*
nVidia 7800 or better*
Intel 4100 Integrated Graphics or better*
I don't know the first thing about the newer processors; the laptop I'm on now has a Core2Duo ULV clocked at 1.3ghz and I know plays SimCity 4 and Civ 4 just fine, but are well below the listed requirements here. What worries me most is when SimCity 4 was released, it had understated some of it's requirements, really limiting play. How much more powerful is something like an i3 processor than the older Core2Duo? And would it be too weak under a game cranking lots of data like SimCity versus a more graphics intensive game such as Battlefield?
The newer Intel chips are much stronger, both from a processing power point of view, and also the integrated graphics capability.
For compute,
The Athlon 64 x2 4000+ has a passmark number of 1081.
The lowly G530 is 2273.
The G850 is 2801.
On the graphics side, I think you are looking at a bit more than integrated graphics.
Something like a 6670, or a GT440.
But, it is so easy to add a graphics card later that I would try out the integrated graphics first. You might end up saving yourself $65 that a 6670 or GT440 would cost.
Or... you might decide to splurge on a much stronger card.
theidiotthatisme
7
I was completely surprised by just how much more powerful the newer processors are, thanks for the passmark! Here's a list of components that I've picked so far:
Case: Silverstone GD05B
http://www.amazon.com/SilverStone-Aluminum-Steel-Computer-GD05B/dp/B0036WTDGQ/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=XR6M64B8CQGD&coliid=II3SSFM6K37XA
Motherboard: Asus M5A88
http://www.amazon.com/ASUS-M5A88-M-6Gbps-Micro-Motherboards/dp/B0053YM6QY/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=XR6M64B8CQGD&coliid=I1XLAFWBFB9B07
Processor: AMD FX-8150 Black Edition (Is there a non-black edition of this?)
http://www.amazon.com/AMD-FX-8150-8-Core-Edition-Processor/dp/B005UBNLFK/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=XR6M64B8CQGD&coliid=I2YITU0QHY0O9P
XFX AMD Radeon HD 7770 Black Edition
http://www.amazon.com/XFX-FX777AZDB4-Edition-1095MHz-Graphics/dp/B007A44VAE/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=XR6M64B8CQGD&coliid=ICDPEXZM5FGGW
ADATA DDR3 1600Mhz 8GB Kit
http://www.amazon.com/ADATA-Gaming-1600Mhz-Desktop-AX3U1600GC4G9-2G/dp/B003E1TQCK/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=XR6M64B8CQGD&coliid=I2BUG0T76PXLWJ
Antec EarthWatts 380 Watt 80 PLUS Bronze
http://www.amazon.com/Antec-EarthWatts-EA-380D-BRONZE-Supply/dp/B002UOR17Y/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=XR6M64B8CQGD&coliid=I2H4BMRZ55209Y
WD Caviar Blue 500GB
http://www.amazon.com/Western-Digital-Caviar-Cache-Desktop/dp/B00461G3MS/ref=wl_it_dp_o_pdT1_nS_nC?ie=UTF8&colid=XR6M64B8CQGD&coliid=I2TG2YF6EKK0RH
Asus DVD-RW
http://www.amazon.com/Asus-24xDVD-RW-Serial-Internal-DRW-24B1ST/dp/B0033Z2BAQ/ref=wl_it_dp_o_pdT1_nS_nC?ie=UTF8&colid=XR6M64B8CQGD&coliid=I183E2YUDLA1VH
Windows 7 Home Premium:
http://www.amazon.com/Microsoft-Windows-7-Home-Premium/dp/B002DHGMK0/ref=wl_it_dp_o_piT1_nS_nC?ie=UTF8&colid=XR6M64B8CQGD&coliid=I24KWOQKA7YOVU
I calculated the power supply needs using http://extreme.outervision.com/PSUEngine and it came up to 233W Minimum and 283W Recommended. The total price for everything as is it is now comes to $895.00
I think the FX-8150 would be a mistake for you.
The passmark numbers have to be looked at knowing the application.
Gaming, for example rarely uses more than 2 or 3 cores, making most of the cores of the FX 8150 useless.
The cores on the intel chips do more work per clock cycle. Bulldozer was a disappointment for gamers. It does represent good value if you will be running multi threaded apps.
Here is a comparison of the FX8150 and a comparably priced 2500K: For you, look at the gaming benchmarks in particular.
http://www.anandtech.com/bench/Product/288?vs=434
theidiotthatisme
7
Thanks for the benchmark information; you're not kidding, especially on single threaded applications and 3D. It's looking like the price of the 3570k and the 2500k i5's are the same currently (not sure if it's just a sale, or what, but I'm not getting it til August so I'll have to just see it then!). I replaced the AMD motherboard and processor with the following:
MSI Z77MA-G45
http://www.amazon.com/MSI-Computer-Corp-Motherboards-Z77MA-G45/dp/B007QWIA9S/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=XR6M64B8CQGD&coliid=I310MFRZOZW20M
Intel Core i5 -3570K
http://www.amazon.com/Intel-Core-3570K-Processor-BX80637I53570K/dp/B007SZ0E1K/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=XR6M64B8CQGD&coliid=I366H9MPE85Q45
Would bring the total build (including Windows OS) to about $912
