Closed Solved
Will i have enough power?
I know you are probably tired of this question but I need to ask it anyway
i5 3570k
Scythe katana 4 cpu cooler
Intel H77 motherboard
2x4GB(8 GB) DDR3 1600Mhz dual channel memory
GTX660 2GB OC
1TB 7200 RPM SATA 3 HDD
DVD/RW
can it run on seasonic 620w Modular 80+ bronze active PFC 12cm PSU?
tell me if i made a mistake because im not so experienced with this
and thanks a lot (:
11 answers Last reply Best Answer
More about will power
  1. Yes your fine. Here is Guru3Ds power supply recommendation:
    GeForce GTX 660 - On your average system the card requires you to have a 450~500 Watt power supply unit.
    If you are going to overclock GPU or processor, then we do recommend you purchase something with some more stamina. Source: http://www.guru3d.com/articles_pages/msi_geforce_gtx_660_twinfrozr_iii_review,7.html
  2. Thanks, also is this a good PSU or should i think about getting a different one? (600-650w)
    That's a good power supply this one right ? http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095
  4. Yes it's this one, im just buying a new pc and don't know much about PSUs
    That is a good power supply do you think you'll ever add another 660 for Sli ? If so then you should get a 750W otherwise your fine
  6. I dont think i will ever use sli but might want to overclock the processor
  7. Best answer
    The power supply you picked is fine you don't half to get the best one that is a very reliable power supply :)
  8. Thanks a lot :)
  9. Best answer selected by Noobita.
  10. Your very welcome!
Power Supplies Components Product
