So i'm trying to make my first build but im not sure how to go with things. I've looked at a lot of parts but i always come out in the $700-800 range which is way over my budget.
I need this computer to play a bunch of video games like wow, minecraft, diablo 3, civ 5, terraria, team fortress 2, and starcraft 2 on high settings. I also do some HD video rendering.
I don't know a lot about the specifics of computer parts but im trying to learn so any feed back id helpful. I'm looking to cut my prices down quite a bit so anything i don't need just tell me and ill get ride of it. I'm also not sure on how much power i needed so i hope lowering the power supply isn't too much of a problem.
So far i've come up with this-
Rosewill Challenger Black Gaming Case $49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Asus M5A97 Motherboard $94.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131767
AMD FX-4170 4.2GHz Quad Core Processor $139.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819106009
G.Skill Ripjaw 8gb Ram $43.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
Windows 7 Home $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
Antec EarthWatts 650w $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044
Western Caviar Blue 500GB drive $74.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
Lite-On DVD burner $17.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Sapphire Radeon HD 6850 Graphics Card $134.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
Besides all this i need to get a monitor so any suggestions on that would also be helpful but that does not need to be included in the build budget.
All help is apreciated!
