Solved
Fan speed of gpu
I recently just picked up a GTX 680 and after gaming for about an hour I noticed my temps were at 70C ish while playing BF3. Inevitably I increased the fan speed to 45% and now my temps during gaming are just fine 50-60.
My question is if it is ok to leave the GPU fan speed at 45% continuously and still have a long life? I understand that 70C under load is not bad, it's just that summer is coming and I want to make sure all my components are cooled. Thanks!
2 answers Last reply Best Answer
More about speed
  1. Best answer
    45% fan is fine if you don't mind the noise. 70C is also fine. Even if the summer temps raise that to 75-80, you will still be fine.
    One thing you could do is set a custom fan curve with MSI Afterburner. That way you could make it run slow at idle and higher depending on the temperature.
  2. Best answer selected by ohyouknow.
Graphics Cards Gaming Fan Speed GPUs Graphics
