GeForce GTX 550 Ti Power Supply!
Hello, im about to buy a GeForce GTX 550 Ti http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625
and i am asking for someones help to find me a decent power supply that will connect this card and will make it run smoothly. I am looking for a power supply around 500W Thanks !
2 answers Last reply
More about geforce power supply
  1. Something like this Antec unit should work. Anything from Antec, XFX, Seasonic, Corsair, and Enermax tend to be good PSUs.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371035
    what are your system specs?
    even though the nVidia specs suggest getting a 500 watt PSU; that is to compensate for low quality PSUs.
    a good quality 350-450 watt PSU would be adequate. (as long as the 12v rail has 12 amps for the card)
    Antec EarthWatts Green EA-430D Green 430W $54.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371034
    XFX ProSeries P1-450S-X2B9 450W $58.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207018
    CORSAIR Builder Series CX430 $44.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
    HOWEVER if you think you will upgrade your gfx card in the next few years go for a 550 watt:
    Rosewill HIVE Series HIVE-550 550W Continuous @40°C, 80 PLUS BRONZE $59.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817182131
    not the best but good quality for the price.
Graphics Cards Gtx Power Supplies Geforce Graphics Product
