Tom's Hardware > Forum > Windows XP > Configuration & Customize > Help with " Start Menu "
Forum Windows XP : Configuration & Customize - Help with " Start Menu "
Archived from groups: microsoft.public.windowsxp.customize,microsoft.public.windowsxp.general (More info?)
I no longer have any icons in the Start Menu " Most Frequently Used
Programs" section.
I haven't cleared out this section and use it frequently.
I have not installed any new software.
Can anyone help please?
XP Home SP2 fully updated.
Paul Woodsford
Remove NOSPAM to reply.
Sponsored Links
Right Click in an open area on the Task bar or Start menu.
Select Properties
Select the Start Menu Tab
Click on Customize
In the middle section titled "Program" with the Clear List button .
Make sure the "Number of Program on Start Menu:" Drop down box is not set to
zero
Change it the your preferred number of program.
Zimran
"Paul Woodsford" <paul.woodsford@virgin.net> wrote in message
news:u3y9RTEGFHA.128@TK2MSFTNGP14.phx.gbl...
:I no longer have any icons in the Start Menu " Most Frequently Used
: Programs" section.
: I haven't cleared out this section and use it frequently.
: I have not installed any new software.
: Can anyone help please?
: XP Home SP2 fully updated.
: Paul Woodsford
: Remove NOSPAM to reply.
Reply to Anonymous
Hi Zimran,
My fault, I meant the section below the Start Menu programs, Recently used
programs. It is empty, and normally has a number of shortcuts to recently
used programs.
Paul Woodsford
"Zimran Douglas" <zmailistREMOVE@THIS.verizon.net> wrote in message
news:%23xftWcEGFHA.2032@tk2msftngp13.phx.gbl...
> Select Properties
> Click on Customize
> to
> zero
> Zimran
> : Paul Woodsford
Reply to Anonymous
I think you are referring to the 'Quick Launch" bar. Right click on a
vacant area of the toolbar and select Quick Launch. This will give you the
items you want, I believe.
Don Dunlap
news:udFMxpEGFHA.2876@TK2MSFTNGP12.phx.gbl...
> Hi Zimran,
> used programs.
> Paul Woodsford
>> Select Properties
>> Click on Customize
>> to
>> zero
>> Zimran
>> : Paul Woodsford
Reply to Anonymous
That section list the Programs that you "most often use"
and my previous suggestion should work unless you have settings or a program
that
automatically removes them.
Zimran
: Hi Zimran,
: My fault, I meant the section below the Start Menu programs, Recently used
: programs. It is empty, and normally has a number of shortcuts to recently
: used programs.
: Paul Woodsford
: "Zimran Douglas" <zmailistREMOVE@THIS.verizon.net> wrote in message
: news:%23xftWcEGFHA.2032@tk2msftngp13.phx.gbl...
: > Right Click in an open area on the Task bar or Start menu.
: > Select Properties
: > Select the Start Menu Tab
: > Click on Customize
: > In the middle section titled "Programs" with the Clear List button .
: > Make sure the "Number of Program on Start Menu:" Drop down box is not
set
: > to
: > zero
: > Change it the your preferred number of program.
: > Zimran
: > "Paul Woodsford" <paul.woodsford@virgin.net> wrote in message
: > news:u3y9RTEGFHA.128@TK2MSFTNGP14.phx.gbl...
: > :I no longer have any icons in the Start Menu " Most Frequently Used
: > : Programs" section.
: > : I haven't cleared out this section and use it frequently.
: > : I have not installed any new software.
: > : Can anyone help please?
: > : XP Home SP2 fully updated.
: > : Paul Woodsford
: > : Remove NOSPAM to reply.
Reply to Anonymous
I forgot to add - after you right click on tha vacant area of the tool bar,
click on Toolbars and then click on Quick Launch.
Don
"Don Dunlap" <dondunlapwhoami@direcway.com> wrote in message
news:4b46b$421a5611$45234021$27012@allthenewsgroups.com...
> Don Dunlap
>> Hi Zimran,
>> used programs. It is empty, and normally has a number of shortcuts to
>> recently used programs.
>> Paul Woodsford
>>> Select Properties
>>> Click on Customize
>>> set to
>>> zero
>>> Zimran
>>> : Paul Woodsford
Reply to Anonymous
Hi Don,
Sorry, it is not the Quick Launch Toolbar, but the section between the Start
Button and the Start Menu above it, where the Frequently Used Program
shortcuts are inserted, that is missing.
Paul Woodsford
news:9ca1b$421a742e$452347f1$31520@allthenewsgroups.com...
> Don
>>the items you want, I believe.
>> Don Dunlap
>>> Hi Zimran,
>>> Paul Woodsford
>>>> Select Properties
>>>> Click on Customize
>>>> set to
>>>> zero
>>>> Zimran
>>>> : Paul Woodsford
Reply to Anonymous
Please type regedit in Start Run, navigate to
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage
and right click StartPage in the tree and choose Export. Export as *.reg file and include file in reply. You open a reg file by right clicking it and choosing Edit.
http://www.microscum.com/mscommunity/
"Paul Woodsford" <paul.woodsford@virgin.net> wrote in message news:%23JNT5WKGFHA.2156@TK2MSFTNGP10.phx.gbl...
> Hi Don,
> Paul Woodsford
>> Don
>>> Don Dunlap
>>>> Hi Zimran,
>>>> Paul Woodsford
>>>>> Select Properties
>>>>> Click on Customize
>>>>> In the middle section titled "Program" with the Clear List button ..
>>>>> set to
>>>>> zero
>>>>> Zimran
>>>>> : Paul Woodsford
Reply to Anonymous
There are 1289 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
