Front panel removal ?
i am currently having alot of problems with my new case " Logisys cs308rd " and i got it when i first started learning about custom builds and i got it cause .... idk im dumb. but anyway the problems i'm having are
!. mounting the front panel fan.
there's a spot wear you can mount a fan in the bottom front for better air flow. but i cant put in my fan because i have no idea how to take off the front panel.
2. screwing on the motherbored.
all that came with the case we're screws that cant even mount my Asrock 970 extreme3 mobo and now im looking dumb with my first build sideways on the floor.
its sort of a disaster so please help me as best as you possibly can nobody ever reply's to this and i need help.
More about : front panel removal
Ask the community
