Closed Solved
Msi Gtx 560ti core speed 950 vs gigabyte HD 7850 core speed 975
i want to know your opinion guys about those two cards as i will buy a new case and confused about which one is the best gaming card
my new pc will have these specifications
Intel® Core™ i5-2500K 3.3GHz Processor
MSI N560GTX-Ti Hawk or Gigabyte AMD Radeon HD 7850 OC 2GB GDDR5 Windforce
Gigabyte GA-B75M-D3H Socket 1155 Motherboard
Western Digital (WD) Caviar Green WD10EARX 1TB SATA 6.0Gb/s 64MB
CORSAIR Vengeance 8GB (2 x 4GB) DDR3 1600 CL9 Dual Channel Memory Kit
and a decent 500w power supply
10 answers Last reply Best Answer
More about 560ti core speed gigabyte 7850 core speed
  1. I'd say go for the HD 7850 because it provides similar or greater performance than the GTX560Ti and consumes much less power.
  2. Also OP, you don't want to be comparing the core clocks on a ATI and a nVidia card. Doesn't work that way.
    And go for the 7850! :)
  3. 7850 is a very solid gaming card, at stock 860Mhz, it outperforms 560 Ti 448 and it is close to 6970/570 performance (according to tom's hardware). So at 975Mhz it will be really fast and might outperform the 6970 and 570. But I need to know what other options you have other than the Gigabyte windforce? It's OK to get it, but note it has lots of 3/5 egg rating at newegg, it's maybe pretty bad...
    But otherwise, I feel sorry for this 7850 card. It performs really good and really fast like a 570/6970... I was happy to see it on stock (each brand has one) in almost every place, but now, they dissapear, most of them are out of stock... It's just like a 680...
  4. thank you folks , i think I'll go for the 7850 . but I've another question about the motherboard . i recently knew that the motherboard plays important role in overclocking <the cpu and the gpu both> is the motherboard listed above a good one in overclocking? or should i replace it
    other options like P67 motherboards
    will it be a greet difference in overclocking performance ?
  5. To be honest the motherboard is not great, P67 would be a much better option :).
  6. about your question of other options or brands of the HD 7850 Gpu , there is the SAPPHIRE
    SAPPHIRE HD 7850 OC 2GB GDDR5
    Is it any good than the gigabyte? considering that it has lower clock "920 MHz Core Clock"
  7. Best answer
    7850. Definitively. See if you can find this card http://www.newegg.com/Product/Product.aspx?Item=N82E16814127663
    Also the performance for nvidia optimised games like bf3, diablo, cyrsis 2 etc may dip. If those are your games of choice, then the 560 ti (esp the twin frozr hawk edn) isn't really a bad option.
  8. Yes the sapphire one looks better
  9. Best answer selected by ms_asem.
  10. This topic has been closed by Mousemonkey
Graphics Cards Core Gigabyte Graphics Product
