Hi Experts! Would really appreciate your input into my planned new build.
I haven’t built a complete rig before but I’ve pretty much changed every component in previous machines so I’m not too intimidated by the prospect.
It’s a home office build that will be primarily used for video processing, heavy duty Excel work and day-trading. Gaming is not in scope here. The rig has to be reliable, stable and capable of running 12+ hours per day without over-heating, whilst handling multiple real-time stock charts via Tradestation. Also, ideally, allowing for a degree of future-proofing.
I’d appreciate your advice on how suitable the spec (is it over-specified? Value-for-money/fit-for purpose? Can I save some $$$ somewhere? Are the components compatible?
So …
[1] Approximate Purchase Date: As soon as possible
[2] Budget Range: Around $1200
[3] System Usage from Most to Least Important: Day trading, video processing & editing, financial & statistical analysis (Excel, MANY array formulae in each workbook),
[4] Parts Not Required: Mouse, keyboard, speakers, monitors
[5] Preferred Website(s) for Parts: Newegg, Amazon, other?
[6] Country: USA
[7] Parts Preferences: Reliability and performance most important
[8] Over clocking: Probably not so as to maintain reliability/stability
[9] SLI or Crossfire: Probably not unless there are advantages for a non-gaming build
[10] Monitor Resolution: Initially 3 x 1280 x 1024, VGA to HDMI via adaptors. Will probably upgrade another time in the future but I want to maintain the capability to use different sized/resolution screens
[11] Additional Comments: I’m not into changing the machine every eighteen months / 2 years so I’d like to maintain an upgrade path for future proofing wherever possible.
My thoughts so far:
MB: ASRock Z68 EXTREME4 GEN3 LGA 1155 - $185
http://www.newegg.com/Product/Produ...k Z68 Extreme4 Gen3 Motherboard (Socket 1155,
CPU: Intel Core i5-2500 Sandy Bridge 3.3GHz - $210
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
MEM: G.SKILL Sniper Low Voltage Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 - $52
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231461
GPU: 2 x EVGA GeForce GTS 450 - 2 x $103 = $206
http://www.amazon.com/EVGA-GeForce-...&keywords=EVGA+01G-P3-1351-KR+GeForce+GTS+450
SSD: Crucial M4 2.5" 128GB - $125
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442
CASE: Corsair Carbide 500R - $140
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139009
PSU: CORSAIR Professional Series HX850 Modular - $175
http://www.newegg.com/Product/Produ...ir CMPSU-850HX Professional Series 850W Power
TOTAL $1174
So …
[6] Country: USA
My thoughts so far:
TOTAL $1174
