Need some advice on psu and other parts.
Last response: in Systems
Hi,
http://img593.imageshack.us/img593/4893/50349808.png Can you guys check out if this build is alright ? My main concerns are:
1.IS that Gembird wireless board the thing i need to cath wi fi? (I have wi fi in my house)
2. Is the ram any good? (I will buy another 4gb later, cuz im low on cash right now)
3. PSU. Is it enough for this build ?
4. Am I i missing any parts ? (i have the speakers)
Also, i may be adding hyper 212 cpu cooler later, once i get cash.
Im buying parts of this web : www.kilobaitas.lt
And i tried to keep this build as cheap as possible to squeeze in that gtx 670.
More about : advice psu parts
Homebuilt system Expert
Good idea going with the 670, good CPU choice, the wifi adapter is old so I would suggest one of the TP Link made ones, RAM is fine, PSU is OK. There are better PSUs out there, but that one will work. Also, I would suggest the hyper 212 Evo cooler instead. It's maybe 10 bucks more but it will give great performance for the price.
Also, the gtx 670 is ref design, no custom cooling. Is that rly bad? are the temps normal? I would have gone for a gigabyte version, but im on a very tight budget. I dont know much abot those wi fi boards, but this is what i found
http://www.kilobaitas.lt/Beviele_iranga/TP-Link/TP-Link...
Or thats not what u suggested? I didnt even look further cuz i wanna it cheap..
Related ressources
Yes that wifi card is much better, as I'm a fan of TP link and how simple they are to set up. The standard gtx 670 reference design is fine, it shouldn't cause any problems. And while I agree with dudewitbow about the PSU not being great, I think it's good enough. If you can though, look around and see if you can find a better quality one.
kokosis said:
So which are good psu brands apart from OCZ and Seasonic ? Are corsair cx series good ? Or maybe this http://www.kilobaitas.lt/Korpusu_mait_saltiniai/OCZ_Tec... would be enough for my build ? The newegg calculator shows 490w minimum, so this would be quite risky, right ?
There's no real such thing as a good brand(except maybe seasonic through a straight line, as they make their own psus). most other companies rebrand psus made by 3rd party companies. as for your question, certain OCZ and Corsair models are good, but the budget modxstream psu and the CX series say isn't as top quality compared to the rest of the series. they are usable, but not top.
So to a budget build that cooler maste would be OK ?
if you had the choice of cooler master v the 2 you mentioned, id go with the ones you mentioned. CM in general has really bad psus and a good handful of them are just slapped on labels promising a higher wattage it cannot fulfill.
if there's the 600w model for sale, aim for that instead, same with if the corsair is there. As wattage goes up, the more it is necessary to buy a more quality psu because after 550w, the voltage starts to act differently and whichever psu has the better voltage regulator is the one less likely to explode and take down anything with it.
Ask the community
