Will this build work together and Run Bf3 on medium settings?
I'm looking to spend roughly £300 and Run bf3 on medium settings or better. I'm not sure if this is an optimum build for the price but you can judge.
Corsair CML4GX3M2A1600C9 LP Vengeance 4GB (2 x 2GB) 1600MHz CL9 DDR3 Memory Module Kit -
AMD HDZ965FBGMBOX Phenom II X4 965 - 3.4 Ghz AM3 Black Edition CPU, Retail Packaged
Asus M5A78L-M/USB3 Motherboard (Socket AM3+, Up to 16GB DDR3, USB 3.0, uATX)
CiT Mars Midi Tower Gaming Case with 2 x Blue LED Fans & LED Display - No PSU
Generic 80GB Sata 8mb Cache 3.5 Inch Internal Hard Drive
XFX HD 6750 700M 1GB DDR5 MINI DP DUAL DVI -£54.99
Powercool 550W 80+ Dual 12V V2.2 High Efficiency PSU
http://www.amazon.co.uk/Corsair-CML4GX3M2A1600C9-Vengeance-1600MHz-Memory/dp/tech-data/B0056J1GTO/ref=de_a_smtd
http://www.amazon.co.uk/AMD-HDZ965FBGMBOX-Phenom-II-965/dp/B002SRQ214/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=33MNE6H3N4F3E&coliid=I80Y2RWEFW2LL
http://www.amazon.co.uk/dp/B0054U7HIO/ref=asc_df_B0054U7HIO8506301?smid=A3P5ROKL5A1OLE&tag=googlecouk06-21&linkCode=asn&creative=22206&creativeASIN=B0054U7HIO
http://www.amazon.co.uk/CiT-Mars-Tower-Gaming-Display/dp/B004UET8GO/ref=sr_1_4?s=computers&ie=UTF8&qid=1340837191&sr=1-4
http://www.amazon.co.uk/Generic-80GB-Cache-Internal-Drive/dp/B0077KWGQ2/ref=sr_1_24?s=computers&ie=UTF8&qid=1340788835&sr=1-24
http://www.amazon.co.uk/XFX-6750-700M-DDR5-MINI/dp/B005NPHNS4/ref=sr_1_39?s=computers&ie=UTF8&qid=1340835406&sr=1-39
http://www.amazon.co.uk/Powercool-550W-Dual-V2-2-Efficiency/dp/B00647OR2A/ref=sr_1_2?s=computers&ie=UTF8&qid=1340836525&sr=1-2
Can you please check whether this will all fit and work together. I think the CPU and MOBO but the rest im not sure.
2 answers Last reply
More about will build work medium settings
  1. if you can stretch to an extra £30 you can get the MSI overclocked HD6850 from overclockers this week, then youll play BF3 ok
  2. I suppose I could do that and that might be a good option.
    More importantly though, as this is my first build, will all these parts work together? If not, could you suggest replacements?
New Build Battlefield Systems
