Need help
Last response: in CPUs
I believe the Intel Celeron D 336 is a LGA 775 CPU (refering to its socket compatibility), the new motherboard you have stated only supports LGA 1155 CPUs. So basically they will not be compatible with each other and therefore it won't work. Will 1155 pin socket accept a 755 CPU? You could fit it into the socket but it will not work at all since it requires 1155 pin CPUs only.
http://ca.gigabyte.com/support-downloads/cpu-support-po...
Ask the community
