Help choosing the case
Hi guys i need help with the case.
What is better in space,ventilation and filters of dust between theses two cases:
Thermaltake V3 BlackEdition http://www.thermaltakeusa.com/Product.aspx?S=1308&ID=1913
vs
COOLERMASTER HAF 912 http://www.coolermaster-usa.com/landing/haf912/home.php?page=specs
The thermaltake v3 is $25 cheaper than the haf912. Which one is better in performance/price? There are a big difference in something between theses two?
thanks in advance
4 answers Last reply
More about help choosing case
  1. Go with the HAF 912 - better airflow and cable management. Alternately you could check out the Corsair Carbide 300R: http://www.newegg.com/Product/Product.aspx?Item=N82E16811139011
  2. thanks. i think i will choose the haf12. i cant buy from newegg cause i live in Argentina,south america. And there is no coirsair at low price in the shops here.
    Is there a store that you do buy from? I can post links if I had that.
  4. Sorry not fully understand what link to put but here are some shops were i can buy it.
    Here in datanex : http://www.datanex.com.ar/hardware/gabinetes.html haf 912 u$s108
    or in this other placer http://www.datasoft.com.ar/View/7356/atx-coolermaster-haf-912.aspx at u$s90.
    other places sell it very expensive. there is too much diferences in prices between the diferentes shops.
New Build Cooler Master Cases Thermaltake Systems Product
