Hi there got a Cooler Master 500 watt power supply in my case right now, this was a power supply that was bundled with my computer case. I had changed it as soon as I got the case to an Antec VP-450 but that is now dead. So just I installed this power supply as a backup until I purchase a new power supply and it has been making an odd noise. Seems like static buildup or something like that. I have a sound recording of the power supply noise while my computer is on, its on the link below. Anyways I disconnected the power supply from the computer and jump-started it and it makes the same noise so I know this is not related to load.
Anyways here is the link, I assure you I have not put any virus or anything malicious in the file. It is just a .wav file that's just a recording of the computer sound, nothing else. You just need to download it and hear it.
http://www.mediafire.com/?hajel5mm8yp2e5f
Edit: Just some more details, I put it in last week and it seemed fine but either it just started happening yesterday or my ears are just being picky. Anyways I ran prime 95 and it went without a hitch so the power supply is able to power on my computer. My build uses around 350 watts at full load.
