Sign-in / Sign-up
Solved
Error Running Diablo 3 Beta, with Radeon HD 6950 2GB card?
  • Graphics Cards
  • HD
  • Radeon
  • Graphics
Last response: in Graphics Cards
May 4, 2012 3:41:26 PM
Hi all I recently bought the Sapphire Radeon HD 6950 2GB video card..........
I installed all properly. And also have the Latest ATI AMD Catalysis 12.4
My friend lend me his Diablo 3 Beta Key, and I install the game to test.
But when I hit the Launch better, it says that my Video Card Driver is not SUPPORTED??????????
What the heck? Isn't Directx 11 the latest driver?
I am sooo confused and frustrated.......
Thank you all
More about : error running diablo beta radeon 6950 2gb card
a b U Graphics card
May 4, 2012 9:01:19 PM
Your monitor is connected to your video card and not to your mobo, right? Also directx 11 isnt a driver...
m
l
May 4, 2012 9:10:02 PM
The last day for diablo 3 beta was also 3 days ago, which will also prevent you from playing it. However, you will still need to go to sapphire's website and download the latest drivers for your video card.
m
l
May 4, 2012 9:15:31 PM
So downloading from ATI/AMD is not enough?
Probably the reason. I will give that a shot
m
l
Best solution
May 4, 2012 9:31:22 PM
There is a tweak in the D3 config file that will just skip right over that screen and allow you to run the game as well. Check the blizzard forums for that. if you hit ESC and not ACCEPT as well, it should launch the game.
Even though the Beta is over, it will allow you into the main screen where it loads a rendered scene for the menu.
Can't wait for this game...
May 9, 2012 2:24:37 PM
Best answer selected by LChenJr.
m
l
