Need a Power Supply - Radeon HD 6950
Alright guys, so I'm going to be ordering a new PSU and I'm trying to find one that'll be the best for my GPU. But at the same time I don't want to spend over 80 dollars or so.
Can anyone find me the cheapest, but the best PSU I can get for my GPU that'll make the GPU perform to the best of its ability.
My GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161372
Thanks,
BoomShotKapow
3 answers Last reply
More about need power supply radeon 6950
  1. It would help to have some more info , cpu , motherboard , ram , hdd and will you be adding another 6850 later on down the road? Where will you be buying it from as in what part of the world do you live in ?
    SeaSonic S12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 80 PLUS BRONZE Certified Active PFC Power Supply
    $84.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096
    If you will only be sticking with the one video card and you have normal other components and can buy from Newegg then this would be the power supply for you. The SeaSonic brand is one of the top quality brands out there.
    SeaSonic M12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
    $89.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095
    XFX Core Edition PRO650W (P1-650S-NLB9) 650W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
    $93.99 and a $15 rebate makes the final price $78.99.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207014
    Actually SeaSonic makes the power supply for XFX so you would get the same top quality.
Radeon GPUs Power Supplies Graphics Product
