I am installing a ep45-ds3r into a antec p182 case. The motherboard has MSG,PW,Speak,HD and RES connectors on the panel. I have the Power Switch, Reset Switch, HD I Led connected. The problem is that there is no MSG wire but there is a HD II LED wire and a Power Led wire(This is 3 pronged and wont fit)
Should I leave the MSG unconnected or should I use the HD II LED wire in place of the MSG wire?
Sorry,I am pretty new to this so excuse me if this question is stupid.
Thanks
-Count
Thanks
-Count
