Solved
Help check my build before i order. Thank you.
Last response: in Systems
June 29, 2012 4:22:18 AM
G.SKILL Ripjaws Series 8GB 2x 4gb ram
2x 2gb ram (idk atm)
ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i3-2120 Sandy Bridge 3.3GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics 2000 BX80623I32120
Nvidia GT 430 (gonna switch soon) (from old computer)
hitachi hard drive 500gb 7200 (from old computer)
cooler master extreme power plus 700w (power supply) (from old computer)
COOLER MASTER HAF 912
Any advice is very welcome. Just need to know if there would be any problem building it with the part i have now.
More about : check build order
June 29, 2012 12:38:33 PM
Change the PSU, according to helpful guys who replied to my thread.
Try seasonic, corsair and XFX. Theyre more reliable. Other than that everything SHOULD work fine. from the research I did, making my own build :D .
June 29, 2012 12:40:02 PM
Everything will work. One thing though. You have an 8 Gb Ram kit in your list and a 4 Gb RAM that you said you dont know atm. Are you trying to fill up all the channels of your MOBO? Also, what is your budget?
June 29, 2012 2:31:27 PM
is it going to work if i fill in the 2x 4 gb ram and the 2x 2 gb ram together? budget is about 600. (dun count the item i already have)
June 29, 2012 2:51:30 PM
How much RAM do you really want? If its for gaming, go for the 2 x 4gb RAM, if its for everyday use, (work and stuff) then you can save up some cash by going with the 2x2gb.
June 29, 2012 2:56:08 PM
I want alot, but saving up money for it as i am a part time student. Those 2x 2 gb ram are from my old computer , so I want to see if it is going to work. No point of wasting those ram :D
June 29, 2012 3:07:39 PM
Wait for a pro to answer if you can put 2 kits of RAM in the mobo. Havent tried putting 4 in. xD
You can sell the 2 x 2gb and then buy more RAM but that isnt much of an option.
If you want 16GB RAM its a bit too overkill. (Unless you wanna play BF3 on Ultra)
But this is according to what I have read, as I am no pro XD
Anonymous
June 29, 2012 3:15:52 PM
June 29, 2012 3:40:47 PM
http://www.kucei.info/g.gif
yeah I want to fill up all the channel of my mobo. budget about 600.
Best solution
June 29, 2012 8:04:55 PM
You can install different sets as long as each pair is identical. You're setup would be fine. You can't just plug and play though. Installation usually is something like this:
1st pair in slots 1 and 3.
2nd pair in slots 2 and 4.
Read your MoBo manual for correct installation and just to make sure that it supports quad channel.
June 29, 2012 9:13:55 PM
Best answer selected by eternalgrace.
June 30, 2012 12:06:35 AM
Nw333 said to change the PSU, but I think it'll be fine for you, especially since you already have it. Cooler Master is a reputable brand for cases and cooling, so the PSU shouldn't be bad. Even if its not very efficient, it is 700W and that setup only uses like 400, so it will be good anyway.
