Suitable case for huge Noctua cooler
littlebloke
17
Hi,
I'm upgrading my case & PSU, my current case is less than spacey... What I would like is a case with adequate space, especially given that the Cooler is massive!!
I also would like something fairly straight forward, i'm not into perspex and LED's
for example, I was looking at: Fractal Design Define XL (http://www.overclockers.co.uk/showproduct.php?prodid=CA-012-FD)
But i'm unsure of the space for the cooler
It also has to cope adequately with SSDs as well as HDDs, I use 2 of each
Any advice would be most appreciated!
This is my current setup:
MOB - Asus P8P67 EVO R3 P67
MEM - 8GB 2x4GB CMZ8GX3M2A1600C9B
CPU - Intel Core i5 2500K
GPU - ATI Radeon HD 7970
ENC - CMaster Elite 430 black
CLR - Noctua NH-D14 Dual Radiator
2 x HDD
2 x SSD
1 x DVD
PSU wise I'll be getting a XFX XXX Black 850W (http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=165)
But its the case i need advice on! :D
tinmann
1,121
I think you will be okay with clearance issues. The case measures (WxHxD): 232x560x561.3mm converted to inches that comes to roughly 9x22x22. The Noctua NH-D13 measures 160mm tall (just over 6.25 inches) and 140mm wide (just over 5.5 inches). I would be more concerned with issues that might arise from the use of Corsair Vengeance ram, the heat spreaders are quite tall and the Noctua with both fans is over 6 inches wide.
littlebloke
17
Thanks tinmann,
That's good to know. You are very right about the memory modules, all of this stuff is already crammed into a case.. I had to manually adjust the Heatsync fan closest to the memory as it simply wouldn't fit. ultimately it works, very tightly, but it works!
I think i'll invest in a liquid cooled solution next with a 2 fan radiator. so much more space!!
LB
