Parts for a new rendering PC (Check)
Last response: in Systems
I'm building my first PC for rendering, and need help on what HDD og GPU I should buy.
(Any upgrades or suggestions is happily appreciated:)
Case: NZXT Phantom 410
Motherboard: Gigabyte GA-Z77X-UD3H
CPU: Intel Core i7 3770K
RAM: Corsair 8GB 1600MHz/VENGEANCE
PSU: OCZ Silencer MK III 600W
SSD: OCZ SSD Agility 3 Series 2.5” 60GB (Boot drive)
HDD: ?
GPU: ?
(Budget: Around 600£ - 750£)
More about : parts rendering check
HDD: ?
GPU: ?
1: id lower the cost of the case by getting something like a antec 302 or a haf 912
2:id lower the cost of the motherboard by using a asrock z77 extreme4
3:you can benefit from getting 16gb of ram
4:that power supply is good enough for 2 low power gpus or a single high power one.
5:for the SSD, id get this
http://www.scan.co.uk/products/128gb-crucial-realssd-m4...
the aglility 3 is kinda garbage
6:for the hard drive, id get a seagate barracuda 1tb 64mb or whatever capacity you need
7:the onboard graphics are pretty good for video transcoding. id suggest getting something like a gtx560ti or a gtx570 if you need CUDA
Related ressources
Binay_97 said:
In Norway it's cheaper to buy Gigabyte GA-Z77X-UD3H then the asrock z77 extreme4, so if there is not a big difference in performance, I going with the GA-Z77X-UD3H :)
oh thats even better. the ud3h is better than the extreme4
Binay_97 said:
Ok, thanks again, but I have a last dumb question. What is the differences between GA-Z77X-UD3H and GA-Z77-UD3H ?
i think the site had a typo. there is no board that is z77-ud3h. they do have a z77-d3h and that is basically the ud3h without the ultra durable PCB. id suggest just getting the ud3h
Ask the community
