I am planning on building my own computer, and have selected these parts.
I plan on using this computer primarily for gaming.
I also want it to be future proof, and have the ability to upgrade components as time goes on.
I will be using a currently owned EVGA NVIDIA Geforce GTX 570 1GB GPU, and plan on utilizing SLI in the future.
Also note that I would like to have a minimum of 8 USB ports on the computer, all of the inputs are USB 2.0, but in the future could be 3.0.
If there are any cables or adapters that are needed or do not work, please inform me!
Please keep in mind room and spacing, I have had troubles in the past with motherboards having obstructions in the way of the GPU.
I would like to keep this build around $1,500, and $2,000 max.
If you have a recommendation, suggestion or find something wrong, please tell me, and explain why. It's good to know, but better to understand why it is like that
CPU: Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I73770K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501
Motherboard: ASRock Z68 PROFESSIONAL GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157263
RAM: CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M4A1600C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233143
SSD: Corsair Force Series GT CSSD-F240GBGT-BK 2.5" 240GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233208
Hard Drive: Western Digital Caviar Green WD10EARX 1TB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136939
Power Supply: COOLER MASTER Silent Pro Gold Series RSA00-80GAD3-US 1000W ATX 12V v2.3 / EPS 12V v2.92 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171056
Computer Case: COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
OS: Microsoft Windows 7 Professional SP1 64-bit - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116992
Thank you very much for your time and suggestions!
-Rotfuchs
-Rotfuchs
