Solved
Need Advice on Case Ventilation
http://www.amazon.com/gp/product/B004351H9G/ref=ox_ya_os_product
my friend got this case earlier then expected will probably start build during the weekend and i didn't check the back vents, on this case. any advice as to how i should position the power supply & the hyper 212 plus
3 answers Last reply Best Answer
More about need advice case ventilation
  1. Best answer
    This guide will tell you everything you need to know: http://www.tomshardware.com/reviews/cooling-airflow-heatsink,3053.html
  2. ah just noticed and read that :X gj me lookin around forums haha..
  3. Best answer selected by Tatsuro.
Build Cases Power Supplies Systems
