I have two Wireless Laptops and a Wireless printer do I need a Router
Hi,
I have two wireless laptops and a wireless printer, do I need a router to connect them
1 answer Last reply
More about wireless laptops wireless printer router
  1. Quote:
    Hi,
    Most ISP supplied wireless routers will run the local domain so no you should just be able to use the one router for lan and internet usage. If your running windows 7 the ease of which setting up a home group is a lot easier and the two laptops will be able to communicate easily and effectively.
Connectivity Wireless Laptops Wireless Printer Routers Wireless Networking
