Approximate Purchase Date: (Not Bought anything yet)
Budget Range: (£200 - £300)
System Usage from Most to Least Important: (Gaming)
Parts Not Required: (keyboard, mouse, monitor, Speakers, OS and DVD Drive)
Preferred Website(s) for Parts: ( www.novatech.com ) I would much prefer this site since it's local to me
Country: (United Kingdom)
Parts Preferences: (AMD CPU PHENOM II 965 BE)
Overclocking: Yes
SLI or Crossfire: Maybe
Monitor Resolution: (I'm planning on using my 1080p Full HD TV)
Here are some of the components i'm thinking of getting
AMD PHENOM II QUAD CORE 965 BE AM3
http://www.novatech.co.uk/products/components/processors/amdphenomx4/hdz965fbgmbox.html
ASRock 970 Extreme3 AMD 970
http://www.novatech.co.uk/products/components/motherboards/amdam3plusallchipsetmotherboards/970extreme3.html
PC Case
http://www.novatech.co.uk/products/components/cases/nov-cougar.html
Power Supply
http://www.novatech.co.uk/products/components/powersupplies/cmpsu-500cxv2uk.html
GPU
http://www.novatech.co.uk/products/components/atiradeongraphicscards/amdhd6850series/hd-685x-zcfc.html
RAM
http://www.novatech.co.uk/products/components/memory-pc/ddr3-pc3-12800/1600mhz/cmx4gx3m1a1600c9.html
- I'm planning on adding more ram at a later date
planning on overclocking the CPU that's why i'm quite concerned about my components.
Overclocking: Yes
PC Case
Power Supply
GPU
RAM
