Hello,
i have a g41m-combo gigabyte mobo 8gb ram dual core processor when i fit the 5400 card i only get 3fps, onboard vga is off and have installed the drivers twice, its not for gaming.
what 5400 did u get?
those are not very fast cards check out this Graphics Card Hierarchy Chart.
both your graphics options are down toward the very bottom, and your onboard is close to the 5400 series cards.
If you can list the make and model of you graphics card we can suggest some options.
