Going to build first pc please look over
Last response: in Systems
Hi there I am completely new to this. I plan on building my first computer, approximate purchase date or date of completion by December 2012-January 2012.
Location NYC
preferred purchasing method: NewEgg.com
preferred System: AMD or Intel doesn't really matter
These are the parts that i picked out. I was trying to stay between $700-$800
please let me know what you think and are these components compatible.
1. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
2. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
3. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
4. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
5. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
6. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
7. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
8. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
please give advice, if you can is there any way to drop the price. main use of this PC gaming- WOW, and SW the old republic. and photo/video editing
More about : build
Homebuilt system Master
You will get more/better responses if you identify the links you provided. Some of us are too lazy to look them all up.
Your list looks decent for now, but the best choices will certainly change by the time you build.
There are new/better/faster/cheaper parts launched every week.
1. http://www.newegg.com/Product/Prod [...] 6811147153
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan-$49.00
2. http://www.newegg.com/Product/Prod [...] 6813138352
BIOSTAR TZ77B LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS-$109.99
3. http://www.newegg.com/Product/Prod [...] 6814500217
ZOTAC ZT-50403-10L GeForce GTX 550 Ti (Fermi) 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card-$149.00
4. http://www.newegg.com/Product/Prod [...] 6817341017
OCZ ModXStream Pro 600W Modular High Performance Power Supply compatible with Intel Sandybridge Core i3 i5 i7 and AMD Phenom-$74.99
5. http://www.newegg.com/Product/Prod [...] 6819115072
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K-$219.99
6. http://www.newegg.com/Product/Prod [...] 6820231461
G.SKILL Sniper Low Voltage Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBSR2-$51.99
7. http://www.newegg.com/Product/Prod [...] 6822236079
Western Digital AV-GP WD3200AUDX 320GB IntelliPower 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive-$69.99
8. http://www.newegg.com/Product/Prod [...] 6827151244
SAMSUNG 22X DVD Burner 22X DVD+R 8X DVD+RW 8X DVD+R DL 22X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM SATA Model SH-222BB/BEBE - OEM-$16.99
Ask the community
