Again no,
If you are looking at kits, then Xspc or Swiftech are the two options to consider,
Xspc's raystorm is a very good block and I'd recommend universal blocks if you consider cooling the cards in future,
you can easily spend $200 on fullcover gfx cards blocks and can't use them on your next cards so uni's are a better option,
lighting is usually either cathode tubes or leds, leds plug straight into the molex line from the psu, cathodes require an inverter which plugs into the psu, and you can get all colours, uv ones help keep your water clear of growth btw,
the sticky is full of handy stuff for you to go over and will help you understand what you need,
but on a $200 budget its going to be a Cpu only loop for now, and add more radiators and gfx blocks later as you can afford to
I think a 240 rad would fit in the front there if you removed the Hdd cage yes, but once you have the case you can measure and then you know the space you have, check measurements of potential rads to see if they fit straight in or require modding
Moto
