Headset problem
  • Default
  • Headsets
  • Skype
  • Components
Last response: in Components
November 9, 2012 12:38:37 PM
Hello
Whenever I talk in Skype friends say they can hear themselves through my mic. My headset isn't loud enough for the mic to pic up the headphone volume. What i have to do?
Pics of my sound settings
http://i.imgur.com/2HsQ1.png
Valmis = ready
Oletuslaite = default device
Ei käytössä = not in use
More about : headset problem
November 10, 2012 11:28:12 AM
Theres probably a short circuit in there somewhere. The quartz signal from your mic must be picking up signals from your wires that are supposed to to go to the headphones. (OR UR FRNDS HEADSET HAS A NOISE CANCELLING SYSTEM[THE OLD ONE!]:D )
November 10, 2012 11:33:23 AM
Okay. Should I get new, or can I repair them?
November 10, 2012 11:39:35 AM
I could be the soundcard but i dont know much about them . I wont want to c ur money wasted so i advise you borrow a friend's headset just to make sure....
November 10, 2012 11:42:30 AM
Repairs are easy once youve noticed the problems. The electric wire carrying the quartz signal is usually purple or green. As for the wire(s) going to the headphones that carries the signals for sound it's hard to guess.
