Plug SATA hard drive with power coming from a different PSU
Last response: in Components
Related ressources:
- ForumHard Drive won't power up with SATA cable plugged in
- ForumHow do I plug in the cables for my optical drive and hard drive ?
- ForumDimension 4600 - run solely with a SATA hard drive - HOW do I do it?
- ForumCircuit Hard Drives become hot when plug it to power
- ForumWhere do i plug in the E- sata wire from case onto the mobo?
- ForumCan I plug a sata com cable into powered up hard drive
- ForumWd 500gb external hard drive wrong power supply
- ForumWhen I update hard drive/sata drivers.. where is that info stored?
- ForumSata Hard drive not being detected at all.. Help?
- ForumSmoke from hard drive . Fault of hard drive or PSU ?
- ForumDo any sata drives use the 3.3volts from the plug ?
- ForumNew build: won't recognize sata hard drive going insane
- ForumHard drive dies then comes back to life?!?
- ForumQuestions About SAS, SATA , and Hard Drives
- ForumSata Cables Coming Loose
- ForumPSU Help
- Forum[Solved] Do I have enough power?
- ForumPSU Recommedations for new mid-level gaming PC
- ForumNeed info on which PSU to buy
- Forum[Solved] What's a good PSU for this build up?
- More resources
Read discussions in other Components categories
