Case and power supply fan always at idle
Last response: in Components
- Case and power supply fan always at the iddle - Forum
- Are power supplies always the loudest part in a case? - Forum
- I don't know what case power supply and fan to use... - Forum
- Case fan and power supply - Forum
- My CPU temps and fan RPM are always high, but it's ice cold inside my case. - Forum
- SolvedShould i connect the case fan into the power supply or the mobo? Forum
- SolvedIf a case has a space for 240mm fan, does it always mean that the corsair h100i's radiator will fit and it will be compatible? Forum
- Power Supply - Case Fan's Forum
- SolvedNeed help hooking up my case fans to my power supply (newbie question) Forum
- SolvedPower Supply - Powering GPU and Case fans Forum
- How to connect molex case fans to fan controller and power supply? Forum
- SolvedHow to hook up 7 case fans to power supply? Forum
- SolvedHow To Connect Case Fans To Power Supply HELP!! Forum
- SolvedCan an Active PFC power supply be converted to an "Always On, Full Power" PSU? Forum
- Power Supply Fan and Case Fans Forum
- Solved3 case fans - plug into motherboard or power supply? Forum
- SolvedPower supply exhaust fan direction in top mounted cases. Forum
- Power supply doesn't have connections for case fan Forum
- SolvedConnecting case fans directly to power supply? Forum
- SolvedI have a poor 550W power supply and can I run r9 280x idle? Forum
- More resources
Read discussions in other Components categories
, don't want to risk losing it. Anyways for uploading just upload to photobucket and copy the forum code. In addition, fans make little difference in terms of temperature. More specifically raising the RPM just a bit does very little change, if you have no fans at all then you have a big problem but since you have fans then changing it won't do much. I recommend a new CPU heatsink or a new computer case if its a small one.
