Power Supply Question
  • Power Supplies
  • Dell Inspiron
  • Computers
  • Components
Last response: in Components
November 9, 2012 9:04:34 PM
I have a dell Inspiron 530S and it will not start. I recently bought a Dell Deminsion that is older. I already bought a upgrade kit from Best buy but it does not work with the older computer. Trying to get something off the hard drive I need. Will any power supply work or do I need a certain model? How will I know which one to buy that will work with my computer? Don't want to waste anymore money. Any ideas??? Thanks!
More about : power supply question
a b ) Power supply
November 9, 2012 10:53:24 PM
Get a eternal HHD enclosure for about $20. Take out the HHD from the bad computer and put it inti the external case(buy a 3.5 inch sata or ide type depending on the HHD connection). The enclosure will com with a power plug and usb cable to connect to a working computer. Now you have a external HHD.
m
l
a b ) Power supply
November 10, 2012 12:52:51 AM
the external drive enclosures is a better bet
m
l
