Solved
First time build - looking for any advice/possible issues
I've been reading a ton of posts on these forums to put together a spec list for my first-time build for a primary gaming PC. The knowledge I've already received on here has been tremendously helpful already, so thank you!
My parts list is finally complete, and I'm pretty sure my brain can't handle any more research. I'm hoping the community here can help me out by taking a look at my parts for any compatibility issues, necessary upgrades, thoughts & general advice.
All parts listed below are from Newegg, and I'd like to order everything from them.
I've gotten the total cost for everything AFTER rebates down to $1016
(I already have a copy of Win 7 64 bit and a 1680x1050 Samsung monitor)
Anyway, here's the list:
CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
MOBO: ASUS P8Z77-V LK LGA 1155 Intel Z77
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
PSU: CORSAIR Enthusiast Series TX650M 650W ATX12V v2.31
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139031
GPU: HIS IceQ X H785QN2G2M Radeon HD 7850 2GB 256-bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161405
HDD: Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5"
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
RAM: G.SKILL Ares Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231558
CPU Heat Sink: COOLER MASTER Hyper 212 EVO
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
Case: COOLER MASTER Storm Enforcer
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119240
Optical Drive: LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Keyboard & Mouse: Microsoft Desktop 400 5MH-00001 Black USB Wired Standard Keyboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16823109232
Wireless Adapter: TP-LINK TL-WN722N Wireless Adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704045
Thank you in advance!
7 answers Last reply Best Answer
More about first time build advice possible issues
  1. You won't need 16GB RAM for a gaming system but otherwise everything else looks good to me.
  2. Thanks for the advice. I forgot to mention I'll also be doing some mild audio recording. I figured since ram is cheap right now I may as well future proof with 16.
  3. That board is rated up to 32GB so you should be good.
  4. Best answer
    The only suggestion I would make is to see if you have a Microcenter nearby. www.microcenter.com
    You can get the processor for $189.99 and that motherboard for $99.99 when you buy them together.
  5. Wow! That's a steal. There is one not too far from me. Is that in in-store promotion only?
  6. Yes. Micro Center only sells processors in their stores.
    You can pre-order and pay online and pick up at the store too.
    If you are going to Micro Center check out their ad...
    http://viewer.zmags.com/publication/11af08e2#/11af08e2/1
    They typically have sale items at better prices than Newegg. Newegg usually wins on regular priced items.
  7. Best answer selected by jsjoe3030.
New Build Systems Product
