hi guyz...
i plan on building a new rig,till now i have never assebled a pc...its always been the entire package from hp or dell...
i plan on building a mid level gaming machine...
my budget is a max of 500-600$ for the cpu,mobo and graphics card
what i have in mind to do :
-non OC processor an i5 2400 or 2500(or should i go for ivy bridge)
-a good MOBO which has support for ivy bridge and support for OC processors(just in case i upgrade to an OC processor in future)
-a good graphics card(550 ti in mind)
-the cooling system,ram,cabinets,fans,hard disk,optical drives...i will figure that out...
processor,mobo and graphics is a real comsfusing issue...
i would happy to any other config. in mind also...
also suggest whether i should go for amd/intel and ati/nvidia...
i believe ASUS is one of the best in MOBOS!
i have week to order all the stuff....
another imp. question is there a diff. in processor performance if a non OC processor i run on a MOBO supporting OC...
sorry for all the queries...this is the first time i am assembling....hope i create a good rig
with ur help..
thanks in advance
with ur help..
thanks in advance
