G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.customize (More info?)
I have had a working multi-boot system (98se, 2000 & xp) for some time with
no problems.
I now have a new machine that I am setting up, and W2K will only boot with
its own copies of ntldr & ntdetect.com. If I use the XP versions then w2k
complains that \WINNT\SYSTEM32\CONFIG\SYSTEM is missing or corrupt, although
the XP ones are supposed to recognise w2k and work (as they have been in my
old system).
Has anyone seen this and figured a solution that doesn't require batch files
to swap the files out, or can guess as to why this is happening?
On the old system I had the OSs on 3 different (SCSI) drives, whilst on the
new one they are on 1 partitioned RAID mirror array.
As far as I can tell the files don't get customized in any way during
install, as I have compared the ones from the new and old machines.
Any suggestions would be greatly appreciated.
Thanks,
Tony
no problems.
old system).
Thanks,
Tony
