Closed
Power draw for build
Last response: in Components
Anonymous
November 10, 2012 7:52:10 AM
cpu [a10-5800k]
mobo [m-itx]
ram [gskill 2x4gb DDR3 2133]
optical [blue ray]
graphics card [6670, already owned will use for dual graphics]
hard drive [run of the mill 7200rpm mechanical]
might add an ssd in the future
i want to know the approximate power supply draw for the build. i would like to slightly OC the cpu and integrated gpu, ill have to see tyhe thermal threshold with a slimline heatsink to see how high i can go. the integrated gpu runs exponentially better with high speed ram thus justifying my ram choice. i may or may not go with blue ray as i already have a dvd-rw, ssd will probably go into it in the future
More about : power draw build
Best solution
November 10, 2012 8:59:01 AM
I'd estimate 300W tops. 350-400W with OC.
I'd reccommend a 400W PSU.
Anonymous
November 10, 2012 1:18:26 PM
ill go with a 450w, there are some descent prices on 80+ gold psus for that wattage that are pretty highly rated
Score
November 10, 2012 4:01:00 PM
Then go for it. Don't miss the deal. :)
Score
Anonymous
November 11, 2012 11:17:28 AM
typically power requirement calculators are drastically off, especially with newer more power efficient components
Score
Anonymous
November 18, 2012 3:56:35 AM
Best answer selected by vanwazltoff.
Score
