I hav a 450watt PSU
+12V rail is 25A rated....
i hav ordered a new PSU crosair 600w (GS600) and ATI radeon HD6750 DDR5
can i get a better GPU that can work on my old PSU??
You could get a 6670, the fastest GPU currently on the market that does not extra power from 6/8-pin PCIe power cables. As vmem suggested, a 7770 should also be well within a 450W PSU's capabilities if it has at least one 6-pin PCIe cable.
my psu dosen't have a 6pin....should i go for HD7750...rather than HD6670
A 7770 should work too, worst case you may need to use a molex-to-PCIe adapter which is perfectly adequate since the 7770 would only be 5-10W over the PCIe slot's power budget at most.
My 2 cents here. Have a 5770 on a 300 watt power supply(mind you the parts had been picked for low power consumption as well) without issues. The 7770 takes less power so unless it is a real bad no name 450 watt psu(you have to watch for those 450-500 watt units with under 250 watts on the 12 volt rail....), it should work
+1 ^
I can't imagine a molex-to-PCIe adapter not working in this situation...
