Well, I finally managed to pull together most of a system, so here's a nearly final check- I've yet to decide upon a Radeon 6870 or a GTX 560 graphics card, but I'm pretty sure it'll be one of those two shortly after the computer itself is complete. Other than those things (and honestly, I'm 50/50 on the GPU there. Could use some opinions from those who've got one and/or the other to help me make a decision), here's what I've got in mind for the PC itself. The unfortunate thing about the HAF 912 is that it doesn't have the USB 3.0, but that's not a dealbreaker for me right now. I can always find some way to install one in the future.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233 - Cooler Master HAF 912
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128502 - GIGABYTE GA-Z68A-D3H-B3 LGA 1155 Intel Z68
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072 - Intel Core i5-2500k. Pretty standard, I figure.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013 - XFX Core Edition PRO550W
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460 - G.Skill Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211588 - ADATA 120GB SSD HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986 - Windows 7 Premium 64-bit.
I'll eventually replace the side panel on the HAF 912 with this- http://www.cmstore-usa.com/haf-912-transparent-acrylic-side-window-panel-oem-package , and then replace the top and front fans with 200mm CM blue led fans and add an additional fan to the side panel as well. I already have a Cooler Master Hyper 212 Plus on the way- the first part of the build to be purchased.
It's a bit more expensive than I originally thought I could go, but with combos factored in (and not including the side panel replacement, additional fans, or the CPU cooler), it comes out to just over $630, minus S&H. I could use some opinions on the build. The CPU and the motherboard are combo'd together for this build, but I'm actually glad I went with the Gigabyte over the Biostar or ASRock combos I'd been considering before.
