Solved
Help me with my first build
Approximate Purchase Date: Before the end of July
Budget Range: 500- 600 before/after
Using the System for: gaming, surfing the internet
Parts Not Required: keyboard, mouse
Preferred Websites for Parts: doesn't really matter
Country: USA
Parts Preferences: doesn't matter
Overclocking: maybe
SLI or Crossfire: either or
really just looking for a computer that can play games with decent frames.
would like to play Arma II mostly
20 answers Last reply Best Answer
More about help build
  1. anyone help me out?
  2. Well how can we find parts for you without a website? :) also, youd be a little over budget cause you still need anOS and monitor.
    Edit: since you live in the US ill find you stuff on newegg :)
  3. you dont have to add a monitor, but an OS would be cool to, thanks again for helping out.
  4. Best answer
    Intel Core i3 Processor i3-2120 $116.99
    MSI H61M-P23 (B3) $47.99
    not a big fan of h61 boards.
    CORSAIR XMS3 8GB (2 x 4GB) $48.99
    Western Digital Caviar Blue WD5000AAKX 500GB $69.99
    CORSAIR Builder Series CX430 V2 $44.99
    that power supply will be sufficient with what the build is.
    GAMMA Classic Series ATX Mid Tower $35.99
    SAPPHIRE Radeon HD 7770 GHz Edition 1GB $134.99
    $119.99 after mail-in rebate card
    that will give you enough graphics power to play Arma II and similar games.
    $499.93 before rebates $484.93 after
    though i really would recommend getting this motherboard instead of an H61:
    MSI H67A-G43 (B3) $79.99
    $59.99 after mail-in rebate card
    $531.93 before rebates $496.93 after
  5. thanks alot man, what I be able to run Arma on with this build?
  6. Good build looniam has there :) Heres my own: http://pcpartpicker.com/p/bi62 over budget but a better card than the 7770.
    yes and D3 maybe some crysis 2 a little single player BF3 . . it isn't too shabby.
    yeah just a little bit over the buget but pretty nice none the less
    What I meant to say was what settings do you think I could run arma on? sorry for the spelling mistake lol.
  10. yw
    have fun
  11. Best answer selected by iTz Jake.
  12. I do have a quick question, what resolution would this be able to handle, and also can I use my TV instead of getting a monitor with this computer?
  13. the 7770 can game @ 1920X1080 in most cases. and it also comes with a few adapters though you might just use the HDMI out or the DVI/D-Sub adapter to plug into the TV's D-sub (vga).
    alright thanks alot man, also do you think I can play like the l4d series and iRacing, or just smaller games?
  15. omg yes.
  16. Anonymous said:
    omg yes.
    Alright another question sorry I'm new to this, is the Cd drive included somewhere here? So I can insert the windows CD or do I have to buy a external drive separately.
  17. Anonymous said:
    lol thanks man
New Build Systems Product
