Tom's Hardware > Forum > Computer Peripherals > CRT Monitors > Monitor Problem Need Help!
Forum Computer Peripherals : CRT Monitors - Monitor Problem Need Help!
I bought a 19" NEC Multisync FP912sb about 6 months ago. For the past 3 days it has been doing this weird wave. The whole screen does the wave vertically from the sides in. It is very annoying. I degaussed it and it did nothing. Any help would be appreciated.
Thanks
Sponsored Links
"Weird wave", do you mean like a continuous jitter, side to side?
That would be electrical interference. If so, the frequency of the jitter will change when you change refresh rates.
Do you have any electrical motors, like an AC fan nearby, or on the same circuit? Do you have another monitor next to the one with the problem? Did you move a power cord parallel to the video cable? If any of these is true then move the item further away.
<b>56K, slow and steady does not win the race on internet!</b><P ID="edit"><FONT SIZE=-1><EM>Edited by phsstpok on 06/16/03 09:32 PM.</EM></FONT></P>
Reply to phsstpok
- 0 +
Thanks for the advice. I will look at the cables and hopefully fix the problem. The wave is a slow and gradual one that kind of warps the screen as it works it's way up. The funny thing is that it was working just fine for 6 months and now it starts this deal. I will try and seperate the cable from everything else to try and prevent the interference. Thanks again for the advice.
Reply to wuut
Quote :
That's different than what I was describing.
Don't know what you have there.
Reply to phsstpok
- 0 +
Thanks for trying. I think it is something to do with electrical interferance but have not found the problem yet. Anybody else have any ideas I am more than open to them.
Thanks
Reply to wuut
- 0 +
Constant electro magnetic fields can damage electronic circuits.
Did you place a power cord or appliance near monitor in the last few days?
Get rid of it.
Reply to nach
- 0 +
Oh yes wuut, please also check your monitor lead from the video card, it could have gone faulty. Probably should not be the electromagnetics first, but its also possible.
Reply to nach
- 0 +
Take it to a friends house and plug it in there to see if the same happens?
I mean just the CRT, plug it into his computer?
Bring his/her computer to your place and try there?
The loving are the daring!
Reply to Flinx
There are 1306 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
