New build, making sure its compatable
I am going with this new build, and wanted to make sure my old PSU would work for it.
Gaming
Corsair 1600 8gb ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186
i5-3570k CPU
AMD 7950 GPU
AsRock z77 extreme4 Mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
I am not worried about power just wanted to make sure it has all the connections I need. But to whom ever goes ahead and asks, I will be slightly OC'ing, and no SLI or Xfire in the future for me.
Here is my old PSU
http://www.ocztechnology.com/ocz-gamexstream-600w-700w-power-supply-eol.html
4 answers Last reply
More about build making compatable
  1. It should work :) It seems to be a pretty decent line of PSU's according to JonnyGURU as well - http://www.jonnyguru.com/modules.php?name=NDReviews&file=print&reid=24
    I would say you shouldn't worry.
  2. cool tyvm. Ill save some cash and give it a go!
  3. If you're gonna OC, and you're sure that SLI/Crossfire is a no, then you can save yourself ~$50 and get this instead.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157304&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
  4. ooh i like that price tag. thanks
Power Supplies New Build Components Product
